Fuel tank issue
Discussion in 'Freightliner Forum' started by scokat, Apr 24, 2018.
  1. scokat
    scokat Bobtail Member
    33
    20
    Oct 14, 2013
    96 classic, 12.7 DD 60, ran out of diesel the other day, gauge said 3/4 full, checked drivers tank, 3/4 full, passenger tank empty. so it seems to be drawing from passenger tank and not returning to passenger tank. any ideas?
    there is no line between thew tanks to level off, so i guess there must be a proprtioning valve. Had this same issue last year, unhooked lines blew them all out, everything worked great till now.
    bad fuel lines, or maybe the proportioning valve on top of tranny?
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    bad cross over valve. how old are fuel lines. are they metal braided.
  4. scokat
    33
    20
    Oct 14, 2013
    not sure on the fuel lines, probably original i would guess.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Replace the fuel valve on trans. they go bad and must be replaced or next time you will have fuel leaking out of over full fuel tank.
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    9 times out 10 when one tank is empty and the other is full I find the tank that is full has a blockage in the suction side. Usually some form of trash.
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Same thing will happen if one of the vents is plugged up.
