Fuel tanks design
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gyrodeputy, Jan 19, 2023.
  1. Gyrodeputy
    Gyrodeputy Bobtail Member
    19
    7
    Apr 16, 2018
    I am swapping out a single 100 gallon tank to dual 50 gallon tanks on opposite sides of a pete 320 to create space for lift axles.
    My question is does the brand of the new tanks make any difference? I found a nice set of freightliner tanks and the fittings are very different than the old pete fittings.
    Does it all come down to there is a supply and a return and as long as they are right I'm good to go, or am I missing something else?
    Thanks guys!!!
  3. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Different diameters
    Rideandrepair Thanks this.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    Need new tank straps and probably drilling holes to mount the new straps.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Both sides just have to be equal. All the fittings and even the length of the hoses.
  6. Gyrodeputy
    19
    7
    Apr 16, 2018
    Both sides? Are you talking about the lines or the tanks? I have been told the tanks sizes are irrelevant.
    Mine will be but wanted to ask regardless.
  7. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Something as small as one tank having a draw or return line longer than the other side can screw up the whole deal. Maybe the longer hose is 4 inches higher than the other side. Are the holes in all the fittings the same size? A side draw mated to a top draw tank would likely be a problem.
    There are numerous trucks through here with different size tanks. Some had a divider put in them for a hydraulic section. Others to work around DEF crap, pumps and such. Size does not matter in this case.
  8. Gyrodeputy
    19
    7
    Apr 16, 2018
    Thankfully this is a pre-emissions truck. But I get the equal lengths on everything else issues. Thanks!
  9. MRMTRANS
    407
    440
    Apr 28, 2015
    I have a FASS. I changed 1 leaky supply line on one tank with a different brand (from Eaton weatherhead to Parker hose-or something like that), both the same size-like #6 or #8, don't remember-and had diesel overflowing from one tank at the fuel cap after a few minutes. It would start overflowing pretty quickly if I just fueled up. I finally figured out it was because the new hose had a slightly different diameter than the brand it replaced. And I am talking like about 0.09 inch difference. Different size of holes and length in the fittings too. The return fuel line from the FASS ported and dumped into the top of the tank. So it drew more fuel from one tank than the other but returned an equal amount. When I would unplug the FASS, I didn't have an overflow problem, but the fuel guage would drop fast as more fuel was drawn from the left tank, but the return fuel from the head wasn't so much as to overflow the right tank. Fuel would reach equilibrium in tanks after sitting. Definitely best to use the same brand and fittings for fuel lines as well as lengths. And make sure the ports are the same distance from the ground. Long winded, I know.
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Definitely not too long winded. I just bought new fuel lines from NAPA and he was going to make them both the same diameter even though the ones I brought in were 2 sizes (8 and 6, I think). My concern was volume, so he made them the sizes I brought in.
  11. MRMTRANS
    407
    440
    Apr 28, 2015
    I am not sure of your point. I guess you are saying that you used 2 different sizes? There are different sizes on 1 tank- the supply line is larger than the return line. We are talking about making sure the supply lines match up, and the return lines match up.
