Fuel tanks
Discussion in 'Ask An Owner Operator' started by Dpose, Oct 13, 2023.
  1. Dpose
    Dpose Bobtail Member
    Oct 13, 2023
    My driver side tank is 140 gallons passenger tank 100 gallons fuel hand shows empty but looked in tank showing about 30-35 gallons or more is my float not working correctly or is it’s best to put the same tank on both side which is 100 gallon tanks.
  3. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    What year truck? Fuel gauges are not accurate at all once you get below half tanks. I have a 98 and when it shows less than 1/4 tank or even empty I still have 50-70 gallons. New float didn’t change it.
  4. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    I wouldn't want to take the tank any lower than 30 to 45 gallons anyway, you don't want to run out.
  5. Cat sdp
    Cat sdp . .
    21,294
    76,114
    Apr 8, 2012
    Orion's Belt
    Lots of trucks have different size tanks . I have 2-135s but the passenger side is split between fuel/hydraulic…. And it’s fine
    Vampire and Flat Earth Trucker Thank this.
  6. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Test the float. Just like an old school carburetor float the arms can be adjusted by bending the rod the float is on. They can be fine tuned. Fill it half full and see what it reads. Get a wood yard stick to stick in tank to get a rough measurement of where half should be. Check gauge and see where the needle sits. Pull sender out and adjust rod accordingly to get gauge to read half. That should make it pretty darn close to as accurate as possible. Watch it as you drop to quarter and yard stick it again to check level to gauge. Fill tank to 3/4 and stick it again. Then full. Pull sender as many times as you have to and adjust till its right. Sounds like ADHD Piece of mind but it’s good piece of mind. Inaccurate fuel gauges are a pet peeve of mine like oil leaks or dirty chrome. Lol
  7. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    I have 2-90 gallon tanks.I've ran it down until I get a low fuel light,but it only takes 120 gallons to fill it at that point.Im assuming I have 30 gallons left in each tank.Winter is coming so I always stop for fuel when I'm down to 1/2 tank on the gauge.It usaully burns 80 to 90 gallons a day.2021 Freightliner, DD 13 automated.
    Vampire Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    If the gauge isn't accurate. The tank is probably in the wrong position.
    The sending unit should be on top. 12 o clock. I think the tank vent also sits the same.
    If the filler hole sits on top. It's in the wrong position. Should be about 11 o clock. Ish.
    I don't know what the float looks like but I'm guess it's a float that moves up and down. Along a straight shaft.
    Not a arm type system. That hole the sending unit fits through is pretty small. Be tought to fit a arm through there.
  9. seamutt
    seamutt Light Load Member
    115
    269
    Jun 15, 2021
    I figure I have around 80 gallons left in my newer T680 (120-100) when the light goes off. That's an annoyingly huge number, but I figure this may have something to do with semi's having problems maintaining flow on steep hills, running tanks dry is very bad, or both?
    Siinman and Vampire Thank this.
