Fuel water separator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, Aug 23, 2018.
  1. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
    How is this thing supposed to work. Anyone seen this before or have experience? 20180823_120004.jpg 20180823_120013.jpg 20180823_120013.jpg 20180823_120013.jpg
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Looks like it has a drain on the bottom to drain water off. I try to drain a few ounces out of mine every few days. I drain into an empty water bottle so I can get a good look and see what I’m dealing with.
    SAR Thanks this.
  4. Kenllah
    226
    113
    Nov 17, 2017
    I open the bottom valve and air bubbles go in but nothing ever comes out 20180823_120019.jpg
  5. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Would that be a bleeder on top of the unit? If it is, crack that open and then open the bottom and see if that drains some fuel/water out.
    Goodysnap Thanks this.
  6. Kenllah
    226
    113
    Nov 17, 2017
    Yes it is. Tried that already. The sediment bubbles up so I know it's not plugged up. Just can't get anything to come out
  7. wore out
    wore out Numbered Classic
    17,309
    214,721
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I bet the drain it self is plugged up
  8. drdesl
    drdesl Light Load Member
    218
    388
    Oct 7, 2015
    Billings, Montana
  9. Kenllah
    226
    113
    Nov 17, 2017
    Air goes in the drain
  10. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    @A5¢ has it. Open both valves. The drain and then the bleed on the top to let air in. Once the pressure equalizes the fuel will drain. On the suction side a small amount of vacuum remains and air will be drawn in the drain.
    SAR and wore out Thank this.
  11. Kenllah
    226
    113
    Nov 17, 2017
    I have opened the bottom until the air stops coming in (the bubbles stop) then open the top as well and nothing. I'm tempted to take the dang thing off
    wore out Thanks this.
