Fuller 9 speed
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckerbangin, Jul 25, 2022.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    Have a 9 speed that slips out of gear sometimes when you you initially go into gear and slips out of gear when not on the throttle. If I take the shift tower off and use a pry bar to to put it in gear it doesn’t slip out. Not sure if it the shift tower or worn shift forks causing the issue.
  3. Big Road Skateboard
    7,066
    40,034
    May 2, 2021
    Detent springs in place?
    lester Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    After that it is usually the sliding clutch and gear worn down. I thank the purple detent spring is the strongest. One of those might buy you a little time.
    Have to knock the top off and look inside.
    spsauerland Thanks this.
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Be sure the shift tower and O ring in top of it are good.
  6. Big Road Skateboard
    7,066
    40,034
    May 2, 2021
    That's a great point.
    @truckerbangin, can you describe "slips out of gear"? Are you having to remove the shift tower to get back in place?
  7. truckerbangin
    268
    45
    Jan 22, 2013
    No just removed it to trouble shoot the problem. The sliding clutches look perfectly fine aswell
    Oxbow Thanks this.
  8. Big Road Skateboard
    7,066
    40,034
    May 2, 2021
    Jumping out of every gear, or just one?
  9. truckerbangin
    268
    45
    Jan 22, 2013
    it doesn’t jump out it just slips out of 1-4/5-8 when I’m not pressing the throttle and coasting. If I hold the shifter it won’t slip out.
    Big Road Skateboard Thanks this.
  10. Big Road Skateboard
    7,066
    40,034
    May 2, 2021
    I know you said the sluding clutches looked good. Have you seen a worn slider? An unknowing eye might think it ok.
    You can see in this pic the sharp edges of the slider. Were yours much more rounded?
