My wife bought me a 959 recently...I am not cb smart...just want to be able to communicate in traffic and enjoy the dumptruckers fighting. What are the best settings for the RF GAIN, RF POWER.....I have to constantly adjust my squelch and its driving me crazy! Wilson 2000 ant. please help!
Galaxy 959 settings
Discussion in 'CB Radio Forum' started by Flatbedder73, Nov 2, 2013.
RF settings are a personal preference... to help your issue, you may try turning squelch off, and set RF gain at a noise level you can tolerate, then adjust squelch just above that setting.
darthanubis and Flatbedder73 Thank this. -
Thank you, I will try that.
Keep the RF power all the way up unless you're running a small 2 pill amp, in which you'll use the RF power to drop the carrier so it doesn't pop the pills.
RF gain only adjusts the sensitivity of received signals on the radio. I run mine wide open but if you only want to hear the truck next to you, then drop it down.
Squelch sets the threshold of signals getting thru. Adjust it to you hear no more white noise.
Keep in mind CB radios are mostly AM, and are very suceptible to picking up interference from electric fuel pumps, ignition systems, neon lamps, fluorescent lamps, lightning strikes, skywave propagation (aka "skip")....so you may find yourself readjusting the squelch quite often under these circumstances.darthanubis and Flatbedder73 Thank this. -
That makes sense...I appreciate the info.
