Galaxy DX-959 Alignment
Discussion in 'CB Radio Forum' started by delta5, Nov 8, 2014.
  1. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Well, I finally did my first cb radio alignment at home. I scored a Kenwood SM-220 scope on Fleabay and it works great for this too. I downloaded the service manual for the radio and did a "by the numbers" alignment on the transmit section. This radio had been "peaked n tuned" by someone that is supposed to be good. First step in the manual was to check the bias current settings. The book specs were 50ma, and 100ma. These were set way too low. Sideband APC was 12.8v. I peaked the sideband power using the 1000 hz tone that my scope provides (nice feature!) and set them correctly. Then I set sideband ALC for about 12-13 watts. I set the am carrier power for about 5 watts dead key, (it was set at 8 ) and then I modulated the radio with that 1000hz tone and set the modulation pot to 100% on the scope. I flat-topped the sine-wave and then backed off the modulation until the sine wave was not distorted looking and perfect. Now when I transmit the modulation % meter goes to 100% and pulls back to about 90% right way so I know the limiter is working properly. Now this radio sounds great and I get compliments on the audio quality. Its loud and very crystal clear. The radio's lights don't go dim on transmit either now LOL.
  3. Ridgeline
    22,702
    122,249
    Its amazing when things are aligned properly.
  4. delta5
    1,193
    7,404
    Sep 9, 2010
    Im still trying to figure out what a "peak-n-tune" will do for me LOL
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    At most "shops" it will make you "peek" in your wallet, and lower your funds to the "tune" of about $20 or so....LMAO
    darthanubis Thanks this.
