Garmin elog
Discussion in 'Experienced Truckers' Advice' started by Short Fuse EOD, Aug 8, 2024.
  1. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Can you edit non driving status such as yard move on garmin?
  3. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Yard move is driving, can not be edited.
  4. Pickleball
    Pickleball Light Load Member
    93
    246
    Apr 9, 2020
    Yard move is on duty.
    tscottme Thanks this.
  5. Siinman
    Siinman Road Train Member
    5,512
    14,165
    Mar 5, 2017
    Kansas City, MO.
    I believe that would be a driving log and unable to change regardless of provider. Only way you could do that in Motive would be to have another driver that is logged with say you like shop work. Then it could be switched to that other driver but would still be a driving log.
  6. goga
    895
    1,586
    Nov 11, 2021
    Earth..
    Ok :cool:
  7. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Yard move is on duty, not driving-yard move. Some eld providers allow you to change that status since it is not considered a driving status.
  8. goga
    895
    1,586
    Nov 11, 2021
    Earth..
    The keyword is "some". Had used 4 of them, none allowed editing when yard move kicked in on driving while on duty. The only thing yard move is made available for is it is not counted towards 11 hrs public road driving, yet it is still driving within company's property, amid not editable towards any off duty status.
  9. ALEX2112
    ALEX2112 Bobtail Member
    12
    4
    Aug 9, 2024
    Yard move - on duty status...should be able to edit
  10. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Do you use a Garmin elog and have tried this on that unit?
  11. ALEX2112
    12
    4
    Aug 9, 2024
    No, I use motive (keeptruckin). Is it your eld or you running under a company and they provide it for you? On any eld you should be able to edit unless it's blocked by admin.
