GCWR
Discussion in 'Experienced Truckers' Advice' started by AriGab, Jul 31, 2025.
  1. AriGab
    AriGab Light Load Member
    62
    27
    Feb 3, 2023
    Hey I apologize if this is in another thread. I also apologize if this is a stupid question lol. So my question is if a truck has a gcwr of 80k and the truck has a gvwr of 50k and you are hauling a trailer with a 50k gvwr but load the trailer with lets say 20k. Is that legal? As long as going across the scales I weigh less than 80k am I ok or does the 2 gvwr's have to equal 80k? Hopefully I explained this ok
  3. buzzarddriver
    3,811
    11,451
    Feb 1, 2011
    Dallas, TX
    GCWR=Gross Combined Weight Registration
    GVWR=Gross Vehicle Weight Registration
    Tractor + trailer + load must be 80K or less, unless registered for a higher gross weight in some states.
    You now need to know the actual weight of the tractor and the trailer. Say it is 32K for the tractor, 10K for the trailer, which equals 42K , which is your TARE weight. 80K - 42K = 38K for the load.
    Remember, these are just examples, so weigh your T/T to be able to see what you could legally haul.
  4. MACK E-6
    49,954
    237,611
    Maybe I’m wrong but I thought the R stood for “rating”.
    That way they can slam you for taking an empty 4-axle truck across a 40K rated bridge, even though when empty you’d be well under that. :rolleyes:
  5. Moosetek13
    Moosetek13 Road Train Member
    14,947
    18,954
    Nov 1, 2010
    Burnsville, MN
    You are not wrong.
  6. Powder Joints
    7,980
    8,377
    Sep 25, 2007
    Rosamond, SoCal
    GCWR is your “Gross Combined Weight Rating”
    MACK E-6 and tscottme Thank this.
  7. AriGab
    62
    27
    Feb 3, 2023
    So unfortunately I was afraid I couldn't ask the question correctly. I understand what gcwr and gvwr mean. I was trying to figure out if you could have a truck with a gvwr of 50k and a trailer with a gvwr of 50k hooked together and be legal? If you added the 2 together it would be 100k. Which is 20k over 80k. I was trying to figure out when you go across the scales if that matters or does it only matter what you ACTUALLY weigh? I know they weigh each axle i understand that as well. So for example if you have 50k plus 50k but only have the truck weigh 40k and trailer weigh 40k are you legal? Even though they are registered for 50k and 50k?
  8. Stringb8n
    Stringb8n Road Train Member
    1,704
    2,230
    Sep 27, 2015
    Some tractors and dry vans have a GCWR of more than 80,000 lbs by themselves. The GCWR doesn't matter neither does the GVWR unless you are in say a GVWR or GVWR restricted lane or crossing a weight restricted bridge as @MACK E-6 mentioned. As far as a scale goes (at a scale house or roadside portable) what will matter is the actual weight of your truck, trailer and load. Long as you are at or under what you are legally registered for, you're good. If you are over then you will get a ticket.
    Just because the GVWR or GVWR of your vehicles states the weight numbers on the manufacturers plate doesn't mean that is what your vehicles are registered for. You'd have to actually look at the registration to determine what weight its registered for.
    MACK E-6, tscottme and AriGab Thank this.
  9. D.Tibbitt
    156,581
    I dont know what u are trying to do. Just register the truck for 80k . like every other truck on the road and be done with it. The government is stupid and you will run into problems when trying to do something outside of normal
  10. AModelCat
    164,195
    The GVW sticker of the truck and trailer simply state what weight the truck and trailer were engineered to handle. It doesn't mean you can legally haul that much though. I believe you'd just register the truck for the max in your jurisdiction or the max your truck and trailer are rated, whichever is lower. You probably don't want to register it higher than the truck/trailer ratings though, you'd be overloading the axles and risking more than just damaging your equipment.
    D.Tibbitt and MACK E-6 Thank this.
  11. buzzarddriver
    3,811
    11,451
    Feb 1, 2011
    Dallas, TX
    Yes, the R is for rating. Sorry for the confusion.
