Gear quest
Discussion in 'Ask An Owner Operator' started by cookderek13, Nov 23, 2017.
  1. cookderek13
    cookderek13 Bobtail Member
    23
    13
    Aug 6, 2016
    Fredericktown Mo
    Got a 400 big cam 3, want a 15spd transmission. What rear end gear choice should be made. Wide range of terrian. Thank you for your replays. I'll be running 11R24.5
    OLDSKOOLERnWV Thanks this.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Depending on tire size you could go anywhere from 3.25 to 3.73. Even up to 4.10 if you’re doing Offroad
  4. Diesel Dave
    9,544
    31,669
    Jan 20, 2010
    Hesperia, Ca.
    Why a 15 speed ? Are you planning to do heavy haul ? The first 5 gears are useless, they are deep reduction. Your basic gonna have a 10 speed. 13 is the way to go.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Yea 13 or 18 or 8LL over a 15 imo. I personally would rather have a 8LL than a 15.
    What size rubber do have? My dad recently swapped out a 9 over (old style against the dash) to a 13 double over .62 ratio in the big hole. With 22.5lp and 3.91 rears @65 was roughly 1675rpm and with the .62 I'd now he's at 1375 at 65 and gained .5mpg.
    For your rears pick your tire size and find out what you need to cruise in the optimal range. 1750ish I would assume for ole ntc.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I liked the reverse in deep reduction, the regular reverse was too fast for tight maneuvers.
    The 15 over has a final gear of 0.78 vs 0.73 of a 13 or 18 speed.
    Another forum said to run it at 1550 rpm at your cruising speed.
    So we need to know what size tires and speed you want to run at.
  7. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I think 1550 is on the low side for a big cam. That's right on the verge of hurting mpg and engine life. They don't lug
  8. OLDSKOOLERnWV
    19,070
    288,039
    I run a Big Cam in my truck. Transmission is a 15613 transferring to Rockwell 3:70's with 24.5 tall. If I run around 1600 RPM when cruising I get my best mileage, but am below the rated speed limit in this area of 70mph.
    Personally, a 15spd trans is a good choice for the low lands, but in my area with constant up and down the 13, 18, are 2 of the better choices. At some point I will be going back to my roots, a 6x4 is in my plans.
    Now I have a friend who runs a A model KW with a B model Cat that loves his 15, big hole against the dash. But he runs a lot of Texas and California so no need to split gears on the HI side, at least not where he goes.
    Be safe out there.
  9. cookderek13
    23
    13
    Aug 6, 2016
    Fredericktown Mo
    11R24.5
  10. AModelCat
    163,926
    Is your 15 a direct or overdrive? I paired my RTO-15615 to a 3.73 rear. I plan on running tall 24.5 and IIRC based off a gearing chart it should put me at around 1500ish mark at 100km/h (62mph). I know for sure the calculator said I could hit 96 mph at governed 2100 RPM lol.
  11. Pup97
    Pup97 Light Load Member
    191
    263
    May 30, 2016
    Tall 24.5 with a 15 speed and 3.90 rears I turn 1650 at 70 mph.
    Roger McG Thanks this.
