Gear ratio over drive or direct for heavy haul up to 110K?
Discussion in 'Heavy Haul Trucking Forum' started by Nick34, Jan 12, 2019.
  1. Nick34
    Nick34 Light Load Member
    73
    21
    Jan 12, 2019
  3. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    Yeah! kR is the go to authority in all things trucking. Just ask him.
  4. Nick34
    73
    21
    Jan 12, 2019
    Thanks for your reply . Right now I have a 2011 freightliner coronado with a dd15 505 hp 1750 torque with an 18 speed double over with 3 55 super 40s it pulles good I run all over including the mountains in British Columbia. The 2 64 ratio from what I'm told should pull about the same with a 1 to 1 ratio in top gear the only problem I'm seeing is startability from a dead stop I was Looking to see if anyone was running this combo doing heavyweight. The 2 64 is very popular for guys running under 80 000 but iv heard very little on guys running it over that. I was strongly against the auto shifts up until a fue years ago now the new ones are saving over .5 mpg so I would like to try one but it looks like I should go with the single overdrive gear to save my clutch
  5. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    My suggestion would be have a mod move this to the heavy haul section and get opinions from the guys loading heavy and wide. I don’t think you’ll like the answers you get because I seriously doubt any of them will tell you to run a setup like that. @MACK E-6 may be around to move this for you.
  6. Ruthless
    Ruthless Road Train Member
    9,153
    90,822
    Aug 28, 2010
    The City.
    Your idea is revolutionary: and you’ll learn VERY quickly why people hate on it. You’ll be saving tons of fuel; about that, there is no doubt.
  7. Humblepie
    5,077
    80,318
    Dec 25, 2018
    Hard to save fuel when you are working the dog #### out of your truck
  8. Oxbow
    Oxbow Road Train Member
    13,625
    141,181
    Nov 24, 2015
    Personally I would not worry about the top end for now and look at the low gear ratio.
    I had an 15818 that was .86 OD. I now have an 18918B, with .73 and it has a slower low gear than the old one.
    I have a spreadsheet that lists the ratios of each gear for each Eaton transmission, but I am away from the office and don't have access to it at the moment .
    I only get up to around 135,000 lbs. gross. I have tall tires and 4.10s, and wouldn't want to get much taller than that.
    MagnumaMoose, BigBob410, SAR and 3 others Thank this.
  9. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    10 direct 10th is the one to one gear but I don't run what you call heavy
    cke Thanks this.
  10. I glide 47
    1,426
    1,523
    Jun 3, 2017
    Don't know if 1st gear is lower than normal
  11. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    He will be saving lots of fuel because the driveline will always be tore out of it, hence the truck wont be rolling down the road burning fuel.
    He will save LOTS of fuel.
