Gear Ratio Question
Discussion in 'Ask An Owner Operator' started by Adamali21, Oct 3, 2020.
  1. Adamali21
    Adamali21 Light Load Member
    278
    180
    Jul 24, 2018
    Hey everyone
    I have a cat c-15 Acert 550 hp 18 speed with a gear ratio of 3.91.
    from previous forums that I posted bought this truck it’s been amazing haven’t had any major issues yet. Now I don’t do any heavy hauling, and the terrain I drive in is all flat, my loads are light. I want to lower my RPMs when cruising. I want to swap out gears from 3.91 to 3.36 or lower. Now I never done this before and is it even possible and if so what parts and components do I have to change. What do you guys recommend. I am currently cruising at 66 mph 1540 rpm right now average 4.8 mpg according to my truck.
  3. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    699
    1,077
    Apr 2, 2016
    From what I recall, an acert liked to be ran lower rpms. What transmission do you have? I would think 3.36 would be much better. You say light loads, do you mean tandem van? Light loads to one guy could be heavy to another.
    D.Tibbitt and Adamali21 Thank this.
  4. Adamali21
    278
    180
    Jul 24, 2018
    Yes Sir dry van under 30k, Eaton fuller 18 speed. I mean is it even possible to swap gears
  5. aaronpeterbilt3787
    699
    1,077
    Apr 2, 2016
    Is your truck a tandem spec truck? 12 front, 40 rears? If so, drop 3.36 gear sets in. Have your ecm recalibrated for different gearing, and while doing that, have a file put in it for increased fuel mileage. Where are you located?
    Vampire Thanks this.
  6. Vampire
    Vampire Heavy Load Member
    771
    27,447
    May 14, 2011
    Transylvania
    Is Mr. Haney still around? From what I remember, he worked magic on the Cats.
  7. Adamali21
    278
    180
    Jul 24, 2018
    12,350 front 46,000 rear. I am located in Michigan
  8. Long FLD
    Long FLD Road Train Member
    12,827
    53,665
    Mar 4, 2015
    It won’t be cheap because you have heavy rear ends, and with the current cost of fuel it will take a long time to recover the cost of doing the swap. But basically you take the guts out of your pumpkins and put new guts in, same as if your rear end went out, only you’re doing it with a different ratio than you currently have.
  9. aaronpeterbilt3787
    699
    1,077
    Apr 2, 2016
    What he said ^
    46 rears will be costly to swap to 3.36. Then you also have the issue of an odd gear ratio in a heavy spec truck when the time comes to sell.
    I know for just a 40 rear setup you’d probably be looking at 10g to swap. 46’s, probably closer to 15g.
  10. Adamali21
    278
    180
    Jul 24, 2018
    so basically only the rear differential
  11. Adamali21
    278
    180
    Jul 24, 2018
    Lmao oh hell no, I can deal with the fuel if it cost that much.
  12. aaronpeterbilt3787
    699
    1,077
    Apr 2, 2016
    Won’t know for sure till you price it out. Take your vin to the dealer or any shop and they can quote your gear sets and labor. All I know is I had to replace a 3.70 front gear set and power divider. Cost was $5000.
    Adamali21 Thanks this.
