Gear Shift Too Hot
Discussion in 'Experienced Truckers' Advice' started by Soldier4jc, Aug 22, 2014.
  1. Soldier4jc
    Soldier4jc Bobtail Member
    Richmond, VA
    My son called me asking what does it mean when the Gear Shift is too hot? I am not quite the mechanic and he and I are truckers. Would anyone mind responding and offer insight as to what this could possibly mean? Should my son pull over before anything serious develops? Hope to hear from someone soon. Thank you.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    These things are relative to where he is getting his shifter temp from and what "too hot" means. Transmissions get hot especially in the summer and especially when worked such as up long grades. This heat will transfer up the through the shifter at least "a ways". If the gear shift HANDLE is "too hot" then something is obviously wrong, but if he's feeling the shift stick down near the base and it's very warm to the touch, that would be normal.
    Not a lot one can do to "check" the transmission fluid as a driver. Typically those are maintenance free for the life of the truck at the first carrier. Most places will pull a top plug and check to see the fluid level is okay at various intervals but this is not on the driver. If it sounds right, ok, if it seems right ok, if the shift stick "too hot to touch", then there may be a problem but nothing the driver himself could check out and verify or rectify.
  4. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    I've got a transmission temperature gauge in my truck. Normally it runs at about 190-200ºF, but pulling or descending a grade will bring it up to about 220-230ºF.
    Did your son notice the heat during or after pulling or descending a grade, or was this just normal on highway cruising?
  5. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    I also have a temp gauge for the tranny....highway running loaded it's anywhere from 170-190* in the summer.....book for the transmission (Eaton-Fuller 8LL) says about 100* over ambient is normal.....
  6. lester
    2,956
    8,077
    Jan 2, 2012
    NW, Iowa
    Why can't a driver check the transmission fluid level? Requires an adjustable wrench is all
  7. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Seriously? You think somewhere there is a company DRIVER who is going to go buy a creeper, crawl under a truck, ruin a set of clothes, to check a transmission fluid level that is more or less "permanent" and is normally only checked by authorized technicians? Let's be real, shall we? All company drivers here who have checked their truck's transmission fluid level, raise their hand ..... waiting .... I did not say a driver could not check a transmission fluid level, I thought I indicated this is something a driver normally does not do ... kind of like a driver does not normally check the camber of the steers on each and every pre-trip.
  8. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Why not? I did when i was a company driver, but then i have extensive knowledge of trk's and years of experience working on them
  9. j_martell
    284
    184
    Jun 12, 2014
    Part (most) of my job as a company driver is keeping the wheels turning.....the dirty #### is my favorite part.....:)
  10. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Could be a multitude of things with a transmission getting to hot, low oil level or oil in trans is way past it's useful life,bearing coming apart inside, oil cooler partially plugged or without knowing the make or model of trans it could be a restricted coolant flow thru the cooler. Some are internally cooled or external
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I think if it could be the difference between walking and driving I could find a piece of cardboard and slide under the truck with an adjustable wrench to made sure there's some oil in there at least. I know you were talking tongue in cheek but there's so many guys on this website that make everything such a big deal.
