General Lee not working
Discussion in 'CB Radio Forum' started by Oilfieldtrucker123, Feb 25, 2019.
  1. Oilfieldtrucker123
    Oilfieldtrucker123 Bobtail Member
    8
    Feb 25, 2019
    This is a fresh install I have a general Lee in my jeep Cherokee with a k40 with a custom mount above the taillight self tapped to the body. The radio is powered by the 12v cigarette lighter. My swrs are right around 1.5 and I'm not putting out or receiveing.
  3. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,037
    Dec 8, 2012
    hunting...../ retired
    Not trying to be smart , but is the coax hooked up on both ends. Sometimes it’s the really simple stuff.
  4. Oilfieldtrucker123
    8
    Feb 25, 2019
    Yes brand new coax and brand new cb.. the antenna is used.
    Tonythetruckerdude Thanks this.
  5. Tonythetruckerdude
    2,909
    54,037
    Dec 8, 2012
    Might try another antenna for starters. Good luck.
  6. Oilfieldtrucker123
    8
    Feb 25, 2019
    If the current antenna was bad it wouldn't have that low of swrs? Right? But I'll try an antenna from my truck.
  7. Tonythetruckerdude
    2,909
    54,037
    Dec 8, 2012
    You would think so. But electronic gadgetry can be fickle. I’m hitting the simple cheap things to check , if the antenna turns out good then it might get costly.
  8. Oilfieldtrucker123
    8
    Feb 25, 2019
    Gotcha. Thanks for your help
  9. Ridgeline
    22,723
    123,053
    Don't mean to be ... well ... if you have an SWR that you can see on the meter, then you are putting out something.
    Most likely you are suffering from an improper ground of the antenna and possibly what is called a Common Current Mode due to it.
  10. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    Jeeps are notoriously hard. The classic types.
    Oilfieldtrucker123 Thanks this.
  11. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Wouldnt power it via the ciggy lighter either..
