Generator vs battery AC system
Discussion in 'Experienced Truckers' Advice' started by Computertrucker, Sep 17, 2013.
  1. Computertrucker
    Computertrucker Light Load Member
    80
    25
    Sep 7, 2013
    So I might be trading my truck in in the near future, or rebuilding my T2000. Either way I have decided that whichever route I go I am going to invest in either a generator or something along the lines of the NITE battery system.
    I've had friends who have owned tripacks and the like and one with a rigmaster . However it seems like they are constantly putting them in the shop for repairs and that maint is also an added cost.
    I've been reading the battery alternative systems have come a LONG way. With better longer lasting batteries and more powerful ACs. Not to mention less maintenance overall. And a several thousand dollar less initial investment. Not to mention less fuel consumption. Which seems like it would financially be the better alternative.
    However. I haven't really spoken to many people who have had them. I realize the generator will have some advantages, but what I'm looking for is mainly a way to help reduce my idle time when its warm, or cold even, and To help reduce my costs.
    So which do you all prefer and why? Also if you could list your personal experiences with either system. Anyone who has had experience with both systems that could chime in would be most appreciative.
  3. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    my truck has a webasto furnace. so i have heat without running the engine. uses less then half the fuel of engine idle. the newer ones noe come with a digital temp control box. so it works just like a house furnace.
    i have no idea what they cost though but any truck dealer can install them.
    as for a/c. there's a whole ton of ideas what people are using on this forum.
    vadimblr Thanks this.
  4. eiloen
    eiloen Bobtail Member
    29
    5
    Jan 24, 2010
    Nashville, TN
    I saw a place in the midwest that will install a new webasto for either $1300 or $1500 (cant remember exactly). That's absolutely a must-have! As for the tripac vs the others, this is a decision I am also going to start looking into in the future...so I will be watching how you decide.
  5. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    My lease unit has an engine driven tripac, but before that, I drove a company unit with the tripac-e on it. Thank goodness I only had it during the cold season because when I tried the AC, it would trip out and show a dead battery pack. I would have to run the truck during a reset to charge the battery pack.
    I would take the engine tripac any day of the week and twice Sunday. When on a reset, the unit only runs when it is needed. The control box monitors battery voltage and I assume engine temperature and it starts up to bring everything up to where it should be. It only shuts down once all conditions have been met. When running the AC it does run all the time as the engine drives the compressor.
    Maintainance isn't such a big deal. It's a small two cylinder engine, so it should only hold a gallon or two of oil. The service interval is at every 1500 hours or 1000 if not using Thermoking filters. This puts the interval at about every other truck oil change. I've had very few issues with my unit. Drive belt failed one night which isn't too hard to change, just a little tight inside the box, and I had debris clogging up the first filter screen which I have to clean once in a while. Think I got a bad tank of fuel or the tank wasn't cleaned out after manufacture.
    I don't even notice how much fuel it has used, even after a reset.
    I've reset in Laredo Texas with hot and muggy weather and the AC kept my truck very comfortable even with the sleeper divider curtains wide open.
  6. Pilgrim007
    Pilgrim007 Light Load Member
    125
    80
    Sep 9, 2013
  7. Ridgeline
    22,701
    122,173
    The RV furnace is not a good idea. they are not made for the amount of usage and they would not be cost effective if they have issues. A wesbasto or Espar for heat and a coleman on the roof for a/c seems to work.
    With the battery run a/c things, energy has to come from somewhere to charge them and if you are stuck for a couple days, then you may end up idling a while to charge them up.
  8. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    The regional OTR company I almost went with had the battery powered units in their trucks. They said the batteries are good for @ 10 hours with NOTHING else using juice in the truck...... Refrigerator, Microwave, coffee maker, laptop, etc.... And with the units this particular company used, they were installed under the bunk killing any hopes of having any storage space under the bunk. The trucks were 2012-2013 Pro Stars and weren't spec'd out (in my opinion) for an OTR driver who prefers to cook & eat n the truck and spend little time in truck stops. I had to have them remove the passenger seat just to fit my fridge in it:biggrin_2551: One attempt at a night in that small bunk with the battery APU barely keeping things cooled off (was 98 that day) was enough for me, well technically, a few nights being gone for orientation was more than enough for mama, so I'm starting orientation at a local compressed gases outfit next week.
    In a couple years mama and I are going to do the class B expedited gig and we're going with the diesel powered APU unit on our truck.
  9. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Read up on these threads. There is a true wealth of knowledge in there.
    http://www.thetruckersreport.com/tr...or/214140-anyone-interested-in-cheap-a-c.html
    http://www.thetruckersreport.com/tr...perator/211635-generator-for-the-tractor.html
  10. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    I used 2 company trucks with Tripacs. The 1st one was a little trouble since the previous driver never ran APU regens. After a discussion with a tech, I learned how to force a regen and cleaned up the units DPF. After that I only had one problem (an unplugged wire). Cool in summer, warm in winter, 120v power on demand. Used very little fuel.
  11. snowwy
    20,609
    13,323
    Jul 6, 2009
    didn't webasto and espar originally get there start in the rv industry????
    when i was looking for a new temp box for the espar in the truck i was in last year. google kept popping up rv's.
