Getting very high swr
Discussion in 'CB Radio Forum' started by carg618, Feb 24, 2018.
  1. carg618
    carg618 Bobtail Member
    46
    14
    Feb 8, 2018
    I am getting a very high swr reading. 3.5 to 4. I have a 4 foot firestik on a triple mag mount. I live in new York and it is pretty hilly but I shouldn't get 3.5 to 4 swr. What could be the problem. I hear you don't have to ground the magnet mounts idk. My antenna is mounted on the roof too. What could the problem for this high swr be?
  3. Ridgeline
    22,720
    123,290
    It is an antenna issue, not a ground issue.
    Hills have nothing to do with it.
    Remind me why you went to a tri-magnet setup?
    BTShepp Thanks this.
  4. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    What are you using to measure SWR? And is the antenna adjustable?
  5. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Mag mounts do provide good grounding.
    Are you sure the coax is in good shape and not pinched in a door? All connectors good?
  6. carg618
    46
    14
    Feb 8, 2018
    I'm using an astatic swr meter and the antenna isn't ajustable
  7. carg618
    46
    14
    Feb 8, 2018
    The coax looks good. The coax in in a door but isn't jammed in there. I can check it again when I get back
  8. carg618
    46
    14
    Feb 8, 2018
    Cause it's not permantent.
  9. BigJim63
    BigJim63 Light Load Member
    62
    61
    May 1, 2014
    Evansville In.
    Did you put the plastic washer where the antenna screws into the female connector?
  10. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Assuming the plastic washer is correctly placed....If ant is not adjustable then if im correct its not ment for the band your useing it in..
