Glad Hand Seals
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tderrick, Mar 6, 2015.
  1. tderrick
    tderrick Light Load Member
    106
    22
    Jul 26, 2014
    Nashville, TN
    OK... Rookie driver - replacing my tractor gland hand seals for the first time.
    a mechanic on a U tube piece said to install the seal with big end inside the glad hand first, which I did. The
    ones I removed were opposite - small side mounted inside the gland hand ... as are the ones on the trailer.
    When you mount the big side in first, this leaves the smaller, but thicker side to make contact with the opposite
    glad hand. The ones I removed had the larger, but thinner side outside to make contact - the seal goes to the edge of the
    glad hand.
    The way demonstrated leaves the smaller, thicker side to make contact - leaving about a 1/4 " to the edge of the glad hand.
    hmmmmm...
    How are the experienced drivers mounting these puppies ?
    magoo68 Thanks this.
  3. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You know. That's not a dumb question in the least.
    From my testing they will work fine either way.
    But I've always put the bigger end in the glad hand with the smaller donut part sticking out.
    It protrudes out more for better seal.
    I guess it could just come down to trial & error on what you like best.
    T_Bone and sam_j Thank this.
  6. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
    Thanks guys ... I'm going to stick with the smaller side out as I like the thicker part to make the contact...
  7. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
  8. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    SONOFAGUN!
    According to him I've been doing it wrong.
    12 ga, chalupa, Cetane+ and 2 others Thank this.
  9. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    LOL!
    I tried using the neoprene ones and thought they were junk because they kept falling out, now i know i was installing them wrong!
  10. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    WTF? Ive never had a problem with this. They never pop out the right way. He must get some crap cheap seals. I only use the ones with the stainless steel screen, to keep the bugs out when unhooked. The purpose of the larger seal face is to extend the seal surface area. If yours dont seal that way, your glad hands need to be replaced.
    rank Thanks this.
  11. rank
    9,919
    113,510
    Feb 11, 2010
    LOL I know Cetane. I've never had one come out either. And the "wrong" way is a heckuva lot faster I bet. Notice how the video was cut and edited as he was "finessing" it in there. Prolly took a half and hour and some cussing. Good post though. Thanks to the OP!
    Cetane+ Thanks this.
