Glider Trucks
Discussion in 'Questions From New Drivers' started by doglover44, Nov 25, 2015.
  1. doglover44
    doglover44 Light Load Member
    191
    28
    Apr 30, 2008
    Hearing alot about these what are they ?
  3. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    new truck with rebuilt non emission engine/tranny
  4. GiantBeard
    GiantBeard Medium Load Member
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    Enlighten me... I'm unfamiliar with these technical terms....
  5. Lonesome
    Lonesome Mr. Sarcasm
    11,679
    24,353
    Dec 15, 2007
    Northern Indiana
    It is basically a new cab, sleeper if equipped, front suspension and tires, and frame. You provide whichever drivetrain you desire, be it from a used truck, or something newer.
  6. AModelCat
    164,478
    A plane with no engine is called a glider. Just like the truck glider. You buy it either as a rolling glider, which lacks an engine and you install whatever you want. A non-rolling glider is basically a cab and 2 frame rails. Useful if you total a good truck. Salvage the running gear and drop it into the glider for less than replacing a whole truck.
  7. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    A glider is a new truck with an older rebuilt motor so we don't have to deal with emissions bs.
  8. chris887
    chris887 Medium Load Member
    545
    421
    Nov 11, 2015
    chicago
    It is a new truck with no engine or trans. You have them install whatever engine and trans you want. Most people have a rebuilt pre emissions engine installed. That way they get a brand new truck without having to deal with emissions, def, or dpf. The older engines had more power and better mpg, but pollute more than new engines so they can not be used in a true new truck, which is why people buy the glider.
    GiantBeard Thanks this.
  9. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The glider kit was ment to be a replacement part. You roll a truck and don't want to junk it buy a kit and rebuilt your truck. People figured out that you can get a new truck with with pre emissions engine. As long as your business model keeps you out of California, it is a beautiful thing.
    chris887 Thanks this.
