Going back on the road
Discussion in 'Questions From New Drivers' started by mparker, Sep 27, 2023.
  1. mparker
    mparker Bobtail Member
    8
    10
    Sep 27, 2023
    Greetings Ladies and gentlemen,
    I have been off the road for far too long and have that itch to see the Midwest and West Coast.
    The company I will be driving for doesn't provide internet but is OK with me mounting an antenna and whatnot.
    I like to game on the road during downtime or when stuck at a Walmart distro(I'm sure that hasn't changed..)
    I found a website that offers the big three for cheaper than I can get with my current cell package so I'm excited about that. (still digging to make sure it's my best option)
    To my fellow OTR geeks who like spending an evening running and gunning in various FPS, my question to you all is.
    Gaming on the road, how has your experience been?
    Any install suggestions, I would like to be able to pull
    I have seen the RV community mention things like NAT issues and blah blah,(Pretty sure T-mobile has a static IP)
    Maybe you have some suggestions and so on.
    I am so not spending 2500 on a device with all these features I will never use, I have heard good stuff about Nighthawk and Inseego devices
  3. Chinatown
    Chinatown Road Train Member
    77,687
    184,115
    Aug 28, 2011
    Henderson, NV & Orient
    There's a search engine in upper right corner of this page.
    Insert "Gaming on the road" there and you'll see a few threads from fellow gamers that might help you.
  4. mparker
    8
    10
    Sep 27, 2023
    Yea most of what I found was a year plus old and plans, and tech changes so rapidly that I was hoping someone with up-to-date knowledge might chime in
    Chinatown Thanks this.
  5. Thrasher28
    Thrasher28 Road Train Member
    1,246
    3,548
    Aug 12, 2021
    Bowling Green, KY
    Not the cheapest option, but Verizon's 150GB high speed hot spot on a dedicated Hotspot device has always worked well for me. Good enough for online gaming (FPS, sports, etc.) in 99% of locations. Download games at home and save your data for updates and the gaming itself and I never had a problem with the data cap. Average performance was probably 80ms latency and usually no or very little packet loss. Sometimes as low as 30-50ms depending on area. Not as good as playing at home, but wasn't noticeable. Going into device settings and opting for 4G LTE instead of 5G seems to perform more consistently. I also have 50GB Hotspot on my ATT plan that has helped a couple times with large updates if I want to save my dedicated hot spot.
    The worst places for it seemed to be WA, OR, and NV. The best places were IN, IL, and surprisingly, WY. All in all, about a 98% shot it will work fine anywhere I stop.
    I never had any problems running a console, laptop, or monitor off APU outlets. An Inverter probably has some more fail safes.
    Gaming on the road has been a life saver for me. It allows me to 'get away' while still being in the truck. Also allows me to keep in touch with buddies back home. It adds a bit of clutter to the truck, but well worth it.
    Magoo1968 and mparker Thank this.
  6. Thrasher28
    1,246
    3,548
    Aug 12, 2021
    Bowling Green, KY
    Here's the Inseego MiFi M2100 device I use. Ignore the screen glitch lol. Accidentally stepped on it one time. Probably better options available now. I'm at a truck stop in Shepherd, TX where many reviews said 'cell service is terrible'. Not sure if it's the chipset in the device or what, but I still have 2 bars LTE and was gaming fine a couple hours ago while waiting for my Houston delivery later.
    It's technically unlimited, but only 150GB high speed that's worth using.
    mparker Thanks this.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,476
    Mar 18, 2021
    St Malo mb
    X2 on using lte over 5g .. 5g is overrated sometimes it won’t even load google map location without waiting . I switch to lte and it loads instantly even though both have max signal..
  8. mparker
    8
    10
    Sep 27, 2023
    I just picked up two plans, an unlimited Verizon(160 a month) with a Nighthawk I can put a mimo antenna that is supposed to have zero throttling, and a T-mobile (800 GB month 120) data plan just in case I do run into NAT issues.
    That is about the same as I used to pay at home for Xfinity service and after the tax deduction, it's a savings.
    Magoo1968 Thanks this.
  9. mparker
    8
    10
    Sep 27, 2023
    for sure! the plans I have I can switch between them, 5G right now seems to be congested
  10. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,547
    2,702
    Jan 7, 2023
    So.......$300/month for fast internet just to play games? Wow.....
    tscottme Thanks this.
  11. Big Road Skateboard
    7,080
    40,121
    May 2, 2021
    But it's not your 300$. Everybody is different. I've got no inverter, no TV, no APU, no laptop, nothing.
    3 12v plugs and a cord to charge my GPS and phone.
    But I might get a hankerin and spend 100$ on dinner, so who am I to judge
