Going down the grades HEAVY
Discussion in 'Experienced Truckers' Advice' started by GasHauler, Feb 10, 2007.
  1. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I haven't posted too many messages but have been reading for some time now. I'm retired and have been driving since 1978. I like to get some dialogue going on how drivers go down steep grades with a heavy truck. I drove a gasoline super tanker out of Las Vegas for 10 years before I retired. We had a couple of grades we'd go down and some of them got your attention real quick.
    Remember Hover Dam when they let trucks pass? Or how about the Laughlin grade on the Nevada side? Of course I could only be 80,000lbs. going over the dam into AZ but the Laughlin grade I'd gross about 105,000lbs sometimes.
    This is the way I'd use the brakes. Going down Laughlin was 6° or more so with an engine brake I'd go down no faster than 35mph. I would let the truck drift to 35 then apply steady pressure (like if you were going to stop at a red light) to bring to speed to 25mph then let it drift again back up to 35mph. I've even hauled heavy construction equipment cross country and used this system for years. I've never had any smoke or problems from the brakes except one time when a seal went out and 90wt got on the brake shoes.
    And with the smaller truck at 80,000lbs going down Laughlin I'd still stick to 35mph but hardly had to use the brakes because the engine brake worked just fine. Before they finished the construction on that grade, they'd have a flag man out there stopping traffic for the dirt haulers so you'd need all your brakes to stop.
    I'd just like to see what other drivers do when going down the long and steep grades when their loaded up. I've had some trucks come up behind me on that grade and get pissed because I was only going 35mph but everyone of them would be at the bottom pulled over with smoke pouring off their brakes. I'd just toot the horn and cruise on by.
  3. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,908
    12,210
    Sep 17, 2006
    WY
    I let the jakes do all the work, that way if the brakes are needed they are cool and ready for the hard work of a quik stop.
    Donk Thanks this.
  4. Runamuk
    Runamuk Bobtail Member
    22
    Oct 29, 2006
    Springfield, Oregon
    If most of the "hotrod" drivers had to buy their own brakes, they would have a completely different attitude about going down long grades......
  5. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    That engine brake is the best when they're working right. However, some trucks don't have them especially if the truck was spec'd in the east where's there's hardly any mountains. Plus the engine brake won't hold you to the speed if you're loaded up to 105,000lbs.
    I have to agree with Runamuk. Those "Hotshot" drivers would change if a few items popped up besides brake cost. Like having a big rock in the one lane road and finding the need to stop but they can't. Or their brakes catch fire and burn their job down. That happened to 2 drivers coming south out of Goldfield NV and they were loaded with explosives. Luckly they got away and it was late at night so there was no traffic when the trailer blew sky high.
  6. asphaltcowboy762
    asphaltcowboy762 Bobtail Member
    10
    Feb 10, 2007
    Virginia
    I use to run California in the early 70's and I know going down the Grapevine or Donners Pass, you could heat up quickly if you didn't know what you were doing. I had always been told to get your speed way down and apply a steady pressure on your brakes and don't let up. If you were to let up, air would get inbetween the brake shoe and the drum and would cause it to heat up. Now this is back in the days when you didn't have a jake. Now a days, some of the jakes/engine brakes don't do the job they are suppose to do and if you tell the shop about it, all you hear is "can't do nothing about it, it is set to factory specs."
  7. MACK E-6
    49,922
    237,249
    That's how a smart man does it when that's possible.
  8. cdr
    cdr Light Load Member
    84
    Jan 1, 2007
    west va.
    because i'm a newbie, this might be a stupid question but what gear did you take that grade in? i'm trying to cash in on your experience before i face that situation myself. we did learn how to upshift and downshift in school, and how to control the truck, but we were never taught anything about down grades.
  9. Brickman
    12,908
    12,210
    Sep 17, 2006
    WY
    Each truck's jakes work at different levels of efficiency. If the hill is steep, 6% or more grade and the load is heavy I'll get down to as low as 5th gear. I can always up shift if need be. That might not be a good idea if you don't understand your truck and how it reacts. Too slow down a grade just means you went slow. Too fast down a grade could mean you are dead at the worst. At the least the brakes over heated.
    5% and not at full weight you can use a higher gear.
    Mack you would be amazed at how many "not smart" drivers there are that let it rip going down. It makes me cringe. But I guess if you have had an experience with brakes gone and minutes from death that would tend to put the fear of God in you.
    I did and it will give you a new appreciation for what a grade can do.
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    The best thing you can do is throw out that saying "you go down in the same gear you came up". You'll want to pick the right gear for the right speed. On the Grapevine there's a speed limit of 35mph so find out what gear is best for 35mph. However, if you've never gone down a 6% grade I suggest going 10mph slower than the posted truck speed limit until you know more about the hills.
    Brickman made an excellent point. If you go down too slow then you go down too slow.
    Just have alot of respect for grades and always keep in mind something could happen that would require all of your brakes.
  11. Chillwag
    Chillwag Light Load Member
    161
    32
    Nov 9, 2006
    Vancouver, Wa
    I like the saying "you can go down the mountain as many times as you want too slow, but you can only go down it once too fast".
    I ran in the Portland aria for a year pulling double milk tanks, and yes the jakes can hold a 105,500 lb truck on a 7% grade like Maryhill (US 97 at the OR/WA border) without having to stab break like Gas Hauler, but then I would be in low range (4th gear) and have the engine wound tight (1800-2000) with the fan over-ride on. Once you find the gear that you can "drift" with the jake on full and slow down you are in the rite gear, now you can toggle your jake to the medium or low setting to adjust your speed without jerking the load with your breaks
