Good Batteries... Help???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jsnap, May 26, 2013.
  1. jsnap
    jsnap Light Load Member
    77
    7
    Apr 10, 2008
    ststen island NY
    Hi all at first a was pissed when I thought my batteries said no more... LOL So when i was telling a friend #### im pissed i put these Napa regular commercial 31 batteries in and only got 3 yrs of trouble free service almost to the day out of them and all of a sudden see you.... His answer was are you nuts 3 yrs no problems that was great stop ######## but im not sure..... Whats say you guys is 3 yrs good from reg commercial 31,s nothing special 100.00 each???? Also please if you guys can whos got the good batteries now where should i buy and what brand???? Like i said regular commercials none of them big buck batts... Thanks all
  3. rollin coal
    rollin coal Road Train Member
    13,591
    27,952
    Mar 29, 2008
    TN
    Just curious if you checked all the cables to make sure they are good and especially cleaned all the connections? My batteries got weak about Wednesday, when i got home by Friday and shut it down it wouldn't fire back up. Cleaned all connections and it started like a champ. Before you buy batteries have the old ones load tested and clean the connections.
    Sent from my droid using Tapatalk 2
  4. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    I have EXTREMELY good luck with NAPA batteries... made by Deka.
  5. special k
    special k Light Load Member
    89
    38
    Sep 6, 2008
    Ontario Canada
    3 years isn't too bad. Thats when the the CAT branded batteries I use start to show their age. The one that are in the truck now are 4 years old and you can tell when you start it up after the cooler/tv has been on for a full 10/12 hours. I just load tested them and they tested on the low side of acceptable but didn't drop any further and they were all equal. I'll check them again in Dec. when I clean the connections for winter. BTW these are some of the lower cranking amp batteries(700CCA) after using 1000 CCA batteries for years.
  6. jsnap
    77
    7
    Apr 10, 2008
    ststen island NY
    Yeah I took all 3 out to charge them 1 at a time so I cleaned every thing up... Actually checked them soon as I took them out just with the volt meter and 1 was 12.5 the other 2 were 12.1 so I new they were low opened the caps topped them off and so I fired up the chargers... I have 2 and i borrowed 1 charger... Rite off the 12.6 started bubbling in all 6 cells but the other two took a while to come back but 1 cell in each never bubbled so its time....I actually took all 3 to autozone and there in house machine is great the days of load testing is over all electronic testes the machine even told us how far of the cca was from what it was supposed to be and sure enough the two had real high resistance so there toast... Just wondering what to replace them with..
  7. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    IMHO--part of the problem is 3 batt's I know some brands have done this at times--but I have had 3 different Paccars(Petes)and solved the problem adding the 4th Batt that should have been there in the first place. Of course YOU NEED to be sure the ENTIRE charging system is up to snuff--especially all cables and connections. Also I only use 1000ca batts--less strain--now at retail they are more expensive--but deals can be found--I have posted this before--but Deka makes a big chunk of all batts out there--and I see you r from Staten Island--their PA plant is only about 2 hours away from you--so Unless you never leave the metro--you probably get pretty close--and they sell all their blems at a very reduced price--course I have 2blues-a yellow and a red--LOL--but all four for under $200
    Good Luck:biggrin_25519:
    jsnap Thanks this.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I always bought mine at truckpro, price & availability. always lasted just over 3 years. last ones lasted 3 years 6 months, then while in my driveway, they went dead. on a sunday afternoon. only place open was napa. got the 3100 series. they are in now. cannot say how they will do, just yest. but bought at least 4 sets over time & never lasted much over 3 years. always over 3, just on borrowed time after the 3 year mark.
  9. jsnap
    77
    7
    Apr 10, 2008
    ststen island NY
    Si am i to understand that the East Penn Plant (DEKA) in Lyon Station PA has a retail store on site where they sell there blems and ill assume none blems out of ????
  10. ‘Olhand
    6,750
    16,653
    Jan 18, 2011
    Yes they dock out website
    Dekabatteries.com
  11. wndrwtr
    wndrwtr Medium Load Member
    301
    187
    Mar 12, 2007
    Texas
    I use the OPTIMA yellow top batteries. Have had the same four in my two diffrent trucks. They are now 8 (yes, EIGHT) years old with no problems. I started useing them when I found out my 3,500 watt inverter was causing the lead/acid type batteries to fail at an extreme early date. Was lucky to get 24 months out of the lead/acid battery.
    MNdriver Thanks this.
