Good Set Up?
Discussion in 'Ask An Owner Operator' started by GoneAgain, May 20, 2015.
  1. GoneAgain
    GoneAgain Bobtail Member
    5
    May 7, 2013
    I'm looking at a 2005 379 EXHD with an 18 speed tranny 550 Cat with 3:36 gear ratio to pull a reefer trailer and possibly a low boy trailer. Is a good set up to pull heavy weight. I just don't know about 3:36 ratio. Thanks in advance.
  3. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    what do you consider heavy weight?
  4. TripleSix
    133,056
    The unanswered question remains.
    For a reefer it would be great. As far as the lowboy goes, he didn't give any details on the trailer either, so I will assume he's talking about a 2 axle. It will do the job you need it to do. Most of the time, you shouldn't see more than 94000 lbs.
    The thing that you have to be careful about is, that big motor. A proper running 550 horse should be stout. You go hill climbing, and the rpms drop but seemingly hold at 1000 rpms or less. On a long climb, those EGTs get too hot for too long and you will wind up burning holes in the tops of your pistons. So you have to learn to resist the urge to play King of the Hill. Downshift. There's no shame in downshifting. Let those 18 gears do the work. Keep those rpms above 1300 and you should be okay on a hill. Let the gears do the work. It's the primary reason to buy an 18 speed.
    GoneAgain Thanks this.
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I had an 04 KW, same specs, pulled a reefer for years, then a 2 axle rgn, always had plenty of power. If it's set at 1850 torque it will do you good.
