Goofy engine temp question
Discussion in 'Volvo Forum' started by 6cuda6, Dec 17, 2020.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    So i know this is going to be very dependent on air temperature but how long does it take before you see coolant temperature on your gauge when idling? Im just trying to figure out if the thermostat on the engine I have is stuck open as i will have oil temp showing on the gauge but nothing on the engine coolant gauge [ i know the gauge works because it will move eventually] and i do get heat from the heater.....
    I don't have another truck to compare it to so i cant tell easily and i know diesels don't produce really good heat at idle.......i'm sure it wouldn't hurt to change the stat anyways but if i dont have too.....lol.
  3. AModelCat
    164,601
    Just feel the upper rad hose. If it gradually warms up, its likely the t-stat is stuck. If it stays cold, then suddenly warms up the t-stats are probably fine.
    062 Thanks this.
  4. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Mine will stay low, if it’s cold enough and winds blowing hard enough. Brand new thermostats. Fast idle, or Driving, it will come up. The difference seems to be below freezing, and especially depends on the wind hitting the radiator. I once had to put cardboard in front of a new Company Truck to get heat. It was -57 wind chill though.
    6cuda6 Thanks this.
  5. 86scotty
    86scotty Road Train Member
    4,700
    12,898
    Aug 27, 2017
    Appalachia
    @6cuda6, does your Volvo have the display screen between the speedo and RPM? You can toggle through the guages with the button on the lever right of steering wheel and see a digital coolant temp. My dash guage never matches the digital guage. I use both to kind of get an average when I'm warming up or pulling a hard hill.
    Rideandrepair Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,314
    10,238
    Jan 30, 2012
    Charlotte, N.Carolina
    doesn't it depend on what truck Goofy is driving?
  7. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    For my truck, the coolant temperature stays about 20F above the oil temperature. The lowest reading of the coolant gauge is 130F. It usually takes 15 minutes in warm weather or 30 minutes in freezing weather to reach 160F oil temperature.
    6cuda6 and Rideandrepair Thank this.
  8. 6cuda6
    259
    176
    Oct 9, 2020
    Yah it does and thanks, i never even thought to look to see if it had a digital reference.
    86scotty Thanks this.
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    How long does it take till you heater starts blowing warm with the heater set on fill hot, if it does not get hot in just a few min. the t/stat is not working? I had a truck that you had to drive 10 mi. till it got any heat going put new ones in and it was blowing hot before I got around the truck ck. every thing on a cold morning.
    6cuda6 Thanks this.
  10. 359 classic
    359 classic Bobtail Member
    17
    23
    Jan 22, 2020
    The older engines like my Big Cam III take a loooong time to make the needle move when cold outside. The newer engines are designed to run cleaner hotter and tend to warm up quite quickly. Always best to run a high idle when parked. What engine do you have?
  11. 6cuda6
    259
    176
    Oct 9, 2020
    2008 Volvo D16
