Got fired for not floating gears
Discussion in 'Report A BAD Trucking Company Here' started by Ywing, Jul 7, 2022.
  1. Ywing
    Ywing Bobtail Member
    12
    Mar 30, 2022
    So I just started a dump end job yesterday. Today I was fired because they didn't like that I don't Float all my gears through low/high. I'm young and never really experimented with floating yet and never saw the value in it. The semi Truck I own and drove for 3 years is 1999 Detroit 60 12.7L with a 13 speed. I was driving the company's truck a beautiful Red/Black 2016 KW with a Cummins delete and 18 speed. I'm not sure where to post this I was just wondering if this is a normal thing to get fired over. I was jerky with it learning how these newer ones move and have never driven a Cummins 18 manual. I thought I was starting to get smoother with it compared to yesterday. Also its a small Farming company and I understand wanting to keep the equipment in tip top shape. just suck that I wasn't capable.
  3. AModelCat
    164,569
    Sounds like you're better off without them. A professional floats and uses the clutch according to what the situation requires. Its never a hard and fast rule.
    usamerica, kuzima93, MACK E-6 and 23 others Thank this.
  4. Flat Earth Trucker
    4,313
    16,559
    Nov 19, 2018
    How is it known that you were not floating the gears?
    usamerica, kuzima93, FozzyNOK and 8 others Thank this.
  5. Lonesome
    Lonesome Mr. Sarcasm
    11,690
    24,373
    Dec 15, 2007
    Northern Indiana
    Over the years, I've applied at a few places, who told me you would be fired if you floated the gears. Strange they would fire you for not doing it.
  6. Cat sdp
    Cat sdp . .
    21,297
    76,133
    Apr 8, 2012
    Orion's Belt
    Plenty of jobs out there……
  7. okiedokie
    okiedokie Road Train Member
    13,840
    109,578
    Jun 13, 2011
    PNWET
    That's a crock. It's not you. Like AModelCat said,there's a time & a place for different driving techniques. Good luck.
  8. Geekonthestreet
    Geekonthestreet Medium Load Member
    344
    587
    Jun 27, 2021
    Chicago
    What!? You should have talked to the manager and lied and told him you would float from now on if they showed you how, and then promptly did #### all when you started driving. Schneider tried to fail my driving test for not stopping at a railroad with a non-placarded bulk load. I remained calm and talked to them and said I’d learn to drive their way. Then proceeded to forget whatever the hell they told me to do after I passed. I have absolute confidence you know how to drive a truck.
    Have you ever worked other blue collar jobs? Where the safety guy strolls around and suddenly everyone is OSHA compliant out of thin air? Same idea
  9. bryan21384
    bryan21384 Road Train Member
    15,712
    34,215
    Sep 18, 2009
    Memphis, TN
    Dang man....that's a tough break. Every truck is different and shifts differently. He just automatically assumed you were inexperienced and didn't know how to shift. Some people are anal like that. It's just how it goes sometimes. They want you floating gears like a smooth criminal. Don't worry about it man. You'll land on your feet in no time.
  10. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    If thier concern was that you were not super smooth with your shifts... They must be living in dream land. Every truck shifts at least slightly different, and that change can take a few days to get used to... Even a truck you have driven before, but its been awhile.
    My daily driving truck is an '07 W900 with a turned up CAT and an 18. I can run it all day up and down the roads pulling a tanker A-Train and never turn off the jake brakes but they very rarely burp unless I want them to, and the ride is nice and smooth...
    Today my truck was in the shop for a blown wheel seal... So I got stuck in a much newer Pete with a 10 speed... Lets just say its a good thing I spend most my day driving back in the sticks, because you'd have thought it was my first day in a truck. Missing gears left and right, grinding a few gears, crow-hopping as I take off from a stop. Yeah it wasnt pretty... Unfamiliar trucks take time to learn and adjust to, even for very experienced drivers... I been in and out of trucks of various types and styles for over 20 years. Sure I felt a little ashamed, but I kept at it and improved as the day went on. When I went to get my truck back, I approached the yard hitting every downshift nice and smooth, swung in through the gate, parked it nice and straight, dropped my trailers, moved the truck infront of its normal trailer, and shut it down. I then walked over to the yard man and said, "Not a bad truck, but not a good truck for me... YET."
    As soon as I put my truck into gear it was like all that was just a bad dream... And back out onto the road I went, just as smooth as ever.
    My point is... Dont beat yourself up because you had a rough time shifting a new truck, or because they let you go either. There are other jobs, with lots of other trucks.
  11. Snow Hater
    Snow Hater Medium Load Member
    480
    980
    Dec 26, 2019
    Using the clutch wears them out faster. At least that's what I was told by an "experienced" driver.
