Green air line cable use
Discussion in 'Ask An Owner Operator' started by DANI3L, Feb 12, 2016.
  1. DANI3L
    DANI3L Bobtail Member
    28
    8
    Nov 28, 2015
    Hello everyone,
    I purchased an international 9400 and along with the emergency/service cables there is a green air cable that i do not know what it is used for. I have searched online with no luck. If any of you could shed some light on this that would be great. I have attached an image of it.
  3. Flipflops
    Flipflops Heavy Load Member
    734
    966
    Oct 18, 2015
    Green is your supply for ABS and lights. Blue and red just charge and supply the air for breaks.
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Since when do lights use air???
  5. Flipflops
    734
    966
    Oct 18, 2015
    Since when does air supply abs electrical signs?
    akfisher Thanks this.
  6. AModelCat
    164,571
    My guess is its likely for an air operated trailer accessory.
    BigRedNY and DANI3L Thank this.
  7. Flipflops
    734
    966
    Oct 18, 2015
    What does a red and blue airline do? How do they work?
    77fib77 Thanks this.
  8. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The red air line supplies air to the trailer , releasing the parking brakes and filling all the tanks. The blue air line signal s the valve that applies the brakes (using the air in the tanks ) . Hopes this helps.
  9. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Your extra (green) line was for a lift axle or air power tailgate release , or any thing back there at was controlled by air.
    BigRedNY, tompetty69 and DANI3L Thank this.
  10. DANI3L
    28
    8
    Nov 28, 2015
    makes sense, thanks for your input
  11. Long FLD
    Long FLD Road Train Member
    12,845
    53,757
    Mar 4, 2015
    Follow the line the other way and see what it's hooked to on the cab end. Likely as already mentioned it was for a trailer accessory.
    DANI3L Thanks this.
  12. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    Keeps the light cool.. Must be why LEDs stay cooler then the old style!!
