I've been driving for less than a year. Recently my 2016 Mack pinnacle day cab I started having a grinding noise from the gearbox. This happens in the upper gears 8th 9th and 10th mainly. It happens when I'm trying to accelerate in any one of those gears when I press the throttle go be a loud grinding noise and a spike in RPMs and no increase in power. On the plus side there's no loss of power. Any ideas would be greatly appreciated
Grinding noise
Discussion in 'Questions From New Drivers' started by Jcleve, Jul 18, 2019.
Get the gear box oil changed. Probably going find a good bit of metal in there.
A spike in rpms??
magoo68 and Intothesunset Thank this. -
When I'm driving an eighth, 9th or tenth and I press the throttle the grinding noise begins in the RPMs will jump 2 to 300. I assume that's because I'm applying throttle obviously but the power is not providing torque. That's just my guess.
I'll recommend that to the mechanic when I bring it in. It's a company truck I just don't want to be on the side of the roadCOBB2070 Thanks this.
Bad clutch , bad gears.
magoo68, FlaSwampRat and Jcleve Thank this. -
RPM spike would be the clutch slipping. Maybe clutch is making noise. I never had one make noise but when they wear out they slip
MartinFromBC, okiedokie, Lepton1 and 1 other person Thank this. -
If the rpms are truly rising, without the truck speeding up, it will be something to do with the clutch. I can't explain the grinding noise, but if it is gaers and it slips, you would be dead in the water.
MartinFromBC, Intothesunset and Jcleve Thank this. -
Putting it into the shop tomorrow. I just wanted an idea how to explain it to the breakdown Department. Thanks for all the advice. I had a feeling was along those lines but I wasn't certain
MartinFromBC, COBB2070 and Intothesunset Thank this. -
May just need the clutch rod adjusted. Does the clutchbrake work?
MartinFromBC Thanks this.
