I have a 2009 Cascadia with 60 series.the engine is rated@1550 trq.everyone I talk to says motor is non upratable.can anyone tell me if there is a shop,or person with Detroit codes that can help?
grtrucker
Discussion in 'Freightliner Forum' started by grtrucker, Feb 7, 2014.
Page 1 of 3
That motor is in a bad spot. Up untill 2006 they only had EGR and no DPF. In 2007 they starter using DPF with no DEF fluid. later they started using the fluid (i think like 2010?) and built a whole new engion. The S60 with DPF is an odd ball motor since the s60 never really did great with DPF. Now if you did a dpf/egr delete you might have more options, but as it stands, the DPF exasht system kinda limits that motor. Unfortunately, they never made a cascadia without DPF and the new ones require DEF as well.
it is possible with removing aftertreatment system. so.... it is not legal
Send me a PM...I can help out
thanks for the feedback
thanks for the response.what info do you need? engine vin,or model #?
No problem. The engine model number would be helpful.
truck is in shop,i will get back with you next week. I did have the diesel doc in Effingham,il hook up to truck,and he told me he could"nt do anything.thanks again.
OK no problem let me know...but as the others said, EGR and DPF systems must go...I won't recommend if you go through California.
I run California,and the ports.so i'll have to keep dpf.i just thought I could get ecm tweeked,and atleast 1650 trq.is that possible?
Page 1 of 3
