Hand Held CB
Discussion in 'CB Radio Forum' started by cjb logistics, Mar 24, 2019.
  1. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Trends are old so I'll asked for the lasted reviews:
    Need a hand held unit for a slip seat stint; oh about 3 mile range. Pick up chatter, talk to scale house, etc.
    Uniden, don't care to be buying batteries all the time, but maybe there is a dc charger unit I'm not seeing.
    Midland looks decent and comes with a DC charger.
    Cobra? My 29's are good, so maybe a Cobra hand held?
    Thoughts!
  3. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    One thought: you need an exterior antenna to pick up more than a few hundred feet.
    rabbiporkchop, buddyd157 and Timin770 Thank this.
  4. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I have the Midland 75-822 and it works well with a Lil Wil external antenna. The external antenna is mandatory as stated above
  5. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    I like my handheld Cobra. Definitely use a DC power supply (it’s not a charger) if you’ll be transmitting. Receiving uses far less power but transmitting will drain those batteries. Cobra I know has a low TX setting you can enable to save battery. It’s 1 watt instead of 4. Exterior antenna is basically required. Rubber ducky antenna is a huge performance sacrifice. Buy the coax adapter to attach to an exterior antenna, maybe the truck has one installed already. Or get a mag mount. Rubber ducky antenna inside a vehicle is basically only capable of hearing engine noise. You can see further than you can get out or possibly hear. With an external antenna, you’re basically running a mobile, but with the two cables (coax and power) it’s going to be a messy set up!
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    The more I think about it, unless you run the handheld without an external power supply and antenna, it won’t be any more convenient to use than a mobile. Just get a cigarette power adapter, tie-wrap an external speaker to the CB, set it on the passenger seat, and you’re better off.
    Meteorgray Thanks this.
  7. 25(2)+2
    18,759
    45,960
    Sep 18, 2006
    the road less travelled
    I used a Uniden in a loaner, for some reason, it worked better in that truck than the one I normally drove, haven't had a reason to try it in the 2018 yet.
  8. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    The selling point for me was portability. At the time of purchase I would often fly to an abandoned truck and/or take a truck somewhere and fly home. The handheld fit nicely in my carry-on. I would make an upside-down 'U' with the Lil Will and shove it into my backpack
    Slowmover1 Thanks this.
  9. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    A foam-lined hard case for radio, GPS, headset, chargers, etc makes sense (to me) to drop into carry-on.
  10. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    That's actually a better idea, but with 3-4 days of clothes and toiletries, a big giant Garmin 780, Garmin dashcam etc etc, I have to practically sit on the backpack to get it zipped. And then comes a prayer to the lgood Lord above that TSA doesnt make me open the darn thing lol
  11. Slowmover1
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    Or don’t carry on. I quit that years ago.
