Vibration-pressure plate, pilot bearing, flywheel, or balancer?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Big Road Skateboard, May 6, 2023.
  1. Big Road Skateboard
    6,951
    39,266
    May 2, 2021
    Anybody ever had an issue with one? In 30 years workin on trucks I've never seen one fail.
    I've got an odd pulsating vibration in the engine. I feel it most from 12-1700 RPM's, when I'm either maintaining throttle or coasting. Can also idle up and feel it.
    Clutch operation does not affect it, so I'm thinking pressure plate, pilot bearing, flywheel, or balancer.
    D.Tibbitt and Oxbow Thank this.
  3. Big Road Skateboard
    6,951
    39,266
    May 2, 2021
    FYI, new clutch and pilot bearing/ flywheel resurface last month
    D.Tibbitt, Rideandrepair and Oxbow Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,824
    6,273
    Feb 4, 2009
    They certainly can. It is hard to diagnose because they have no external signs many times. They can dry up or harden up internally or rubber ones start to separate.
  5. Brandt
    Brandt Road Train Member
    4,616
    6,343
    Sep 17, 2012
    They are supposed to replaced every 500,000 miles according to Pittsburgh Power. They got their info from design engineer at Cummins.
  6. Brandt
    4,616
    6,343
    Sep 17, 2012
    201 Road Train Member
    12,699
    26,118
    Apr 16, 2014
    high plains colorado
    Oh yeah, however, on my BCs, they rattled and shook, I never knew anything was wrong, and never replaced one. I do know many Cat motors had a lot of problems.
  8. Big Road Skateboard
    6,951
    39,266
    May 2, 2021
    I'm just gonna replace it. Not many factory ones around. VanderHaags shows one in Sioux Falls. Might try to get a load that way in the morning
    D.Tibbitt and JoeyJunk Thank this.
  9. Brandt
    4,616
    6,343
    Sep 17, 2012
    Back when I had my own truck I had S60 Detroit. After listening to Pittsburgh Power guys I replace mine and put the Harmonic balancer they also sold. I noticed a difference right away. Sometimes I read stories about guys engines keeping braking like a/c bolts and stuff. If you ask most shops people say they never go bad. I probably had about 800,000 miles on my truck before I hear about replacing them.
  10. Big Road Skateboard
    6,951
    39,266
    May 2, 2021
    Just ordered the Vibratech from STS Diesel. 450$ shipped to the house. I'll update when i get it on
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,562
    9,924
    Mar 30, 2014
    Shopping around is best. When I bought mine, I wound up getting it from Pittsburgh Power because it was cheapest at the time. Most recently I think I saw the cheapest at Raney's.
