Harmonic balancer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat sdp, Dec 22, 2014.
  1. Cat sdp
    Cat sdp . .
    21,246
    75,728
    Apr 8, 2012
    Orion's Belt
    Ok so my radiator has to come out...... Question is with 420,000 miles on a c-15 do I replace the balancer now??
    I've always heard do it a 500k.....
  3. PurplePete
    PurplePete Light Load Member
    131
    24
    Nov 15, 2011
    Tyler, Mn
    I know what's posted on the internet but it doesn't hurt to call a Cat dealer for their documented service schedule.
    Cat sdp Thanks this.
  4. Ridgeline
    22,699
    122,078
    Replace it now, it would be easier with the radiator out anyway. While your at it, take a good look at your water pump.
    PurplePete and Cat sdp Thank this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Vibration damper is what most manufacturers call it .. According to Bruce and kr they are toast inside after 500k but most shops say don't bother changing it but guys who do notice a improvement in idle
  6. Cat sdp
    Cat sdp . .
    21,246
    75,728
    Apr 8, 2012
    Orion's Belt
    I believe vibrateck (or something like that) makes both the pp and pdi ones. We'll see tomorrow ... Tks
  7. Cat sdp
    Cat sdp . .
    21,246
    75,728
    Apr 8, 2012
    Orion's Belt
    Cat house service manager says don't change it, unless it's the old 2 piece kind(black rubber gasket around it)..... But would not say what the replacement interval for the viscous one is....
    My cat mechanic who I trust more than cat says leave it........ So it's going to stay.
    SAR Thanks this.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Cat Dampers, to test remove it and bounce it on the tire if it rattles it is junk other than being bent it is good to go, the Damper does nothing at low RPM it is made to remove harmonics above 1750 RPM.
    Cat sdp and EverLuc Thank this.
  9. Diesel Dave
    9,521
    31,507
    Jan 20, 2010
    Hesperia, Ca.
    I replace mine with the Vibratec for a piece of mind. Old one had over a million, so figure what the heck, besides, my engine ain't stock. One of many engine techs I keep in touch with, also said what JohnP3 said, "leave it", But I never listen....... My Cat head had single springs, with the increase power they told me it would ok, I didn't listen, I install the double spring kit. I CALL IT "INSURANCE".
    Cat sdp and SHO-TYME Thank this.
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I would contend that they are not vibration dampers but torsional dampers. They absorb the torsional stresses on the crankshaft that are generated at all RPM's and especially under high power conditions. You want to take out vibrational stuff, then a crankshaft balancer is the ticket, and those are totally a aftermarket add on thing. The crankshaft damper absorbs the stress on the crankshaft, the balancer moderates vibrational inconsistencies.
    Now that being said, without actually cutting open a crankshaft damper, there is no way to determine correctly if it is doing the job or is needing replaced. You cannot tell if the silicon damper material that the damper ring rides on is still viable inside the damper housing. There is no inspection port or such to check. But those that have done all the background stuff on this have determined, a crankshaft damper should be replaced at around 500,000 miles. Some engine owners manuals also state the same thing, but then, seems anymore that many owners can't even find their owners manual let alone actually read it. That is the primary reason we get all this anecdotal "this is the way we have always done it before" type of mechanical advise. And it seems many mechanics and supervisors can't even get engine coolants right, let alone be a expert on crankshaft dampers.
    Some think that spending extra money on adding goo to their oil or a host of other things that are hocked at truck shows and what not are good insurance to make their engine last. They have no problem spending money on stuff that is questionable as to whether it works or not, CB radios that can reach Moscow, RU, looking like a rolling casino going down the road with a million lights on the truck, yet they want to play the role of some sort of bean counting miser regarding stuff like a crankshaft damper that is a major player on engine wear and longevity. Go figure.
    Cat sdp, Heavyd, beltrans and 5 others Thank this.
  11. Cat sdp
    Cat sdp . .
    21,246
    75,728
    Apr 8, 2012
    Orion's Belt
    Ya there's no replacement info in the cat owners manual .... It says ask your certified cat service dealer...
    Anyways radiator is back in.... Balancer is on next years Christmas list with turbos .
    Ho Ho Ho!!
