Hauling a Draper Head
Discussion in 'Flatbed Trucking Forum' started by SHC, Jun 9, 2012.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Monday i am picking up a proto-type draper head from John Deere Development and taking it to Commiefornia..... anyone ever hauled these? Any tricks to securement? This is going to be a BIG one, the biggest they have made yet I was told (52' long, 9' wide and 8' high).... I'll post some pics up once I get it loaded
  3. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    Excuse me ignorance but what is a draper head?
  4. jellybean
    jellybean Medium Load Member
    324
    65
    Mar 1, 2010
    Central MD
    The long piece on the front of a combine that sits horizontal and does the harvesting
    Logan76 Thanks this.
  5. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Unless its something real special, they are pretty much flat on the bottom. straps, and maybe a few dunnage timbers and you should be good to go. google header trailers to see what the farmers used to haul them with. Should be really straight forward.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I have grown up in Iowa my entire life and never once have I heard them called a draper head. Corn head or bean head only.
  7. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    http://www.deere.com/en_AU/equipment/ag/combines/platforms/600d/index.html
    The difference is that a draper head uses a conveyor belt to pull the crop into the center of the head instead of an auger. Makes it feed much smoother. I've never hauled one out of the factory myself, but most of the heads I see have the reels folded up and sitting on the trailer facing up to be narrower. Usually in pairs. But if its 9' wide, they must not be tipping it up? A 52' grain head must be massive.
  8. 25(2)+2
    18,759
    45,978
    Sep 18, 2006
    the road less travelled
    There isn't alot of small grain harvested for grain in Iowa, a cutting platform header was often used for what was direct cut, but for utilizing precutting the grain and allowing it to dry before the combine picked it up to thresh it, a swather was used which often had a draper head. A draper drapes the cut small grains on to a conveyor of canvas or rubberized belting after it is cut to gather it to the center where it is fed into the machine or placed on the ground to dry and later be picked up by a combine equipped with a windrow pickup head.
    From what I understand, there are advantages in capacity and less crop damage to using a draper head over a cross auger type header. It is also lighter in weight for the same width of cut.
    A bean head was adapted from a rigid platform header with a flexible cutterbar which allowed closer to the ground cutting.
    A corn head doesn't use a cutterbar but uses snapping rolls and stripper plates to snap corn ears from the shanks.
    A row crop head had points on snouts, like a corn head, but with a small cutter for each row. These were made by John Deere and were also called bean heads.
    I have been seeing heads and combines being moved on highway for years. A head as wide as the OP described wouldn't be used much except in flat land farming
  9. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    They're using flex drapers now, which are flexing platform with a high speed conveyor belt to the feeder house for gentler grain handling, I've seen the on stands shipped vertically if its just one I assume it'll be sat on your trailer as if it were on the ground, John Deere just released a 40' version, I've only ever hauled 1 and if was on a transport trailer
  10. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Although the one I hauled was not that big, the loaders will tell you how to run the chains for proper securement.
    Pandemic and SHC Thank this.
  11. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Yes, I am mostly worried about the arch in the trailer and the load. But I'm sure they will have dunnage for blocking it. Guess I'll find out Monday morning.
    Its a 45V-203 on a HT-55
    Whatever that means lol
