Hauling pipe
Discussion in 'Flatbed Trucking Forum' started by Bdog, Dec 29, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I have someone wanting me to haul 1,000 joints of 2-3/8 pipe. 32' long I think. Distance is about 150 miles one way.
    No idea how much this weighs can I haul 334 at a time or will it take four trips?
    I have never hauled pipe before. I assume I need pipe stakes to keep it from rolling off the trailer but how many are needed and how tall do the need to be? I can't really visualize how tall this will be on the trailer.
    I assume just place 4x4's under them so they can be forked off and stack away or does it need to be in layers seperated by 4x4's?
    I was planning on at least three belly wraps and then a lot of straps and chains as I hear this stuff likes to shift.
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    2-3/8 will tie down good. I would guess 4ft stakes would be good at 3 or 4 foot intervals. You would only need dunnage under the bottom layer unless they want it otherwise. I believe they come in 30ft joints, approximately 6.8lb/ft, so about 215lb per joint. Maybe 205 joints to a load? I'm not a pipe hauler, but have been around oilfield stuff for a long time
    Bdog Thanks this.
  4. Bdog
    1,057
    877
    Nov 6, 2014
    They don't care how I haul it or secure it the pipe is for a buddy of mine. I just want to do it safely.
  5. mountaingote
    2,026
    7,916
    Sep 22, 2012
    Yup, just stack it in layers, and keep yer straps n chains tight
    Bdog Thanks this.
  6. Bdog
    1,057
    877
    Nov 6, 2014
    Are pipe stakes something you can buy or do I need to make my own? What are they typically made of?
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I've hauled oilfield pipe on several occasions. If it's going to be used, they won't let you chain it, but being as it's for a buddy, it may not matter. If so, I'd stack it all together (some folks don't like doing it that way) in what they call "pyramid" style, gut-wrap front and rear, then chain and/or strap down. The problem with pipe is that there is no good way to prevent forward movement if you happen to be involved in a wreck or something. Build a bulkhead if you can, but I don't know how much it will help. Just keep the load tightly secured. Stop and check it a few times as it may settle.
    As for stakes, we always just used four big ones. Two on each side of the trailer.
    Dominick253 and Bdog Thank this.
  8. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Our pipe stakes were made to fit the specific trailer, but you can make generic stakes from some C-channel that fits into your stake pockets, with a piece of rebar welded across it to keep it from falling thru.
    Bdog Thanks this.
  9. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    You need to figure out pipe specs,
    2 3/8 pipe x 1/4" wall thickness weighs appx 7.5lb per foot or 240 per piece at 32ft.
    334 joints x240lbs= 80,160lbs on your trailer!
  10. nikmirbre
    nikmirbre Road Train Member
    5,581
    10,328
    Jul 27, 2011
    High Point NC
    4 pipe stakes, and they are not required maybe only if the shipper or receiver require them. Good idea to have pipe chocks also.
    Bdog Thanks this.
  11. Bdog
    1,057
    877
    Nov 6, 2014
    I don't think it is quite that heavy. I have built fence in the past with 2-3/8" oilfield pipe and two of us could pickup and carry the 32' joints without too much struggle. They were heavy but I don't think 240lbs of heavy.
