I have a 08 century 60 series i have 2 codes thats came up trying to figure it out before taking it to shop so anything will help thank you. Truck seems to run fine no problems codes are
"brake wh snsr axl 1l rate 136s002 10"
"eng aux out driver 2 sht lo 128s040 04"
Have 2 codes on 2008 century help please
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Agus309, Jan 24, 2019.
Google is your friend .
Looks like an abs sensor code for the first one.
Not enough info for the second. -
Yea not sure it just says "eng aux out driver 2 sht lo 128s040 04"
Any one seen this before?
Constant throttle valve circuit failed low.
Agus309 Thanks this. -
So kost likely is the throttle body? Atleast from what i got from searching online? Thanks
