Hello,
I have a class A CDL and used to drive OTR. I now pull a 32' wells cargo trailer. My company want me to get a hazmat so I can haul Oxidizers.
Does the state randomly drug test a hazmat driver or does the company? I've always wondered what an Owner operator does with a hazmat as far as testing goes. I'm not sure if my company will want to pay for many tests every year if it is mandatory.
Thanks for any input.
Hazmat Drug Testing
Discussion in 'Questions From New Drivers' started by WItrucker, May 12, 2008.
When I got Hazmat here in Massachusetts, the only thing I had to do was be fingerprinted for a background check by Homeland Security. As far as drug testing, that took place when I went with Swift. From what I understand a company can bring you in for random testing.
Drug testing is mandated by the Federal government, which in turn requires companies to test their drivers. The higher the positive results, the higher the frequency of tests required. Kinda like vehicle inspections in that regard. But as far as I know, Hazmat quals don't require any additional screening for illegal substances. Just background check and fingerprinting.
My company only needs be to haul once a month at most. Does the govt know who my employer is in regards to my hazmat? I feel like most big trucking companies test often to save on insurance costs. If my company is not a trucking company will I need to be tested?
Thanks a lot for the info. -
The company is required byt the Federal Govt (not the local state) to perform the test - but what they actually do is hire it out to certified testing companies.
Standard testing is random.. I think 25% of the pool per year (if testing is done more than once a year, your name can come up each time, since the selectees are chosen from the entire pool each time)
IF there is sufficient reason, (i.e. somebody points the finger at you, and the management thinks there's sufficient cause) you can be pulled in on no notice for a 'suspicion' test.
And, of course, if the company wants to foot the bill, they can do random sweeps whenever they want - the gov't guidelines are minimums.
For more details, check out your DOT book - it's all in there. -
My company is not a trucking company. I drive a trailer once a month and am the only one that drives it.
Who cares if someone has you pee in a cup?
The BIGGER issue is why this is worrying you................ -
Knowing how the system works is a good thing - it helps keep you from getting burned. -
