Head gasket replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sheldy, May 21, 2020.
  1. Sheldy
    Sheldy Bobtail Member
    I had a head gasket blow on a Cat C7 engine. I had the head rebuilt and reinstalled it now I can't get the valve cover to stop leaking. It seems to have to much oil pressure under the valve cover. Does anyone have a answer for that?
  3. lester
    2,956
    8,074
    Jan 2, 2012
    NW, Iowa
    I don't know anything about a C7 but a valve cover doesn't have oil pressure under it per say. Sure pressurized oil gets sprayed around inside it but the cover itself isn't pressurized unless it's not vented. Guess I'd start by replacing the valve cover gasket
  4. Stang
    Stang Bobtail Member
    37
    74
    Mar 27, 2016
    CT
    Is it leaking on the exhaust side, towards the back of the engine? If it is, the VC gasket wasn't trimmed properly, and that's where the two ends overlap. It's a fairly common mistake.
    baha Thanks this.
  5. AModelCat
    164,163
    If you re-used the valve cover gasket, start by replacing it.
  6. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    If it is coming from the valve cover you more than likely crimped the gasket when putting the valve cover back on. Remove the cover & check it to make sure it is seated properly.
    Bean Jr. Thanks this.
