Head lights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRD TRANSPORT, Mar 8, 2024.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    03 peterbilt 379 same dam thing .
    Replaced all 4 headlights
    2 low
    2 high.
    Replaced turn signal switch.
    Fuse is good
    Relay new
    Still no lights.
    Any idea would be helpful thanks much in advance.
  3. FLHT
    FLHT Road Train Member
    1,423
    2,531
    Aug 2, 2014
    Got power where the wiring plugs under radiator ?
    Run a ground wire to headlights.
    Had same problem when I put new led headlights in a few years ago.
    Lost the ground
    Magoo1968 Thanks this.
  4. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Thanks for the info.
    Had already checked that and spliced a shaky wire.
    Looked behind dash at light toggle and saw it had melted alittle. Replaced it and put connectors on wires .
    Hard wire so to speak and bingo lights.
    Dam I was ready to throw in the towel and pay someone to fix it.
    I got lucky. ;) .
    Thanks for the tip just the same.
  5. FLHT
    1,423
    2,531
    Aug 2, 2014
    Might want to change that fuse. It should of tripped..
    It's always something.
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Did you go from Halogen to LED? Some require you wire the lights differently.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,475
    Mar 18, 2021
    St Malo mb
    At a former company a co worker ended up adding a marker light under the hood to provide a constant draw on the circuit. His new led headlights would flash otherwise due to the low power draw it messed with his headlight relays or ecm somehow.
    BoxCarKidd Thanks this.
  8. The one california kid
    The one california kid Medium Load Member
    560
    936
    Oct 31, 2023
    "Constant draw on the circuit" you do that to get around the speed limiter the company likes to punish you with. Shhhh, ancient Chinese secret.
  9. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    No not a fan of led headlights
