Headlights off and on
Discussion in 'Experienced Truckers' Advice' started by Wycka, Dec 2, 2020.
  1. Wycka
    Wycka Bobtail Member
    6
    Hello,when I have to drive in the dark my right side headlight sometimes goes off and on again.It hapens 1 or 2 times in 3-4 hours driving with headlights on.Same thing next evening...But only the right side,low or high beems go off and on again.My truck is 2005 Volvo.Where can be a problem?
  3. kemosabi49
    10,976
    47,913
    Jan 13, 2013
    SW Arkansas
    Probably have a loose/bad connection somewhere. Check the connectors from the lights back into the harness. Pull them apart and make sure they are not corroded. I always spray some contact cleaner in them, but I know guys that use WD40 to clean them. Then put a small dab of dielectric grease on each one before re-connecting them.
    tscottme, Cattleman84 and flood Thank this.
  4. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    I had the same problem when the company I previously drove for had all Volvos. The shop replaced the wiring harness and the problem was fixed. The next truck I got (another Volvo) had the same issue on the opposite side. The shop replaced that wiring harness and the issues were resolved.
    I think the idea @kemosabi49 gave you will help you stay moving and not have to go into a shop for it.
    tscottme Thanks this.
  5. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    The harness connectors at the front near the hood hinges is where I would start.
    86scotty Thanks this.
  6. Ridgeline
    22,719
    123,199
    Most likely there is a broken wire in the harness where the hood pivots, very common problem.
    Muddydog79 Thanks this.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Harness or your truck saw a cute Volvo going the other way and winked.
    Moosetek13, Michael H and Hatt91 Thank this.
  8. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    My situation was when I would put my high beams on the left side would completely go out so I pulled the left side head lights and found the problem, gave it a temporary repair but time for a new harness..
  9. Final Drive
    1,573
    2,505
    Jan 21, 2015
  10. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    I drive a 2019 VNL760. I had the right side low beam go out on me. Turned out to be the wiring harness going to the headlight assembly. Where it had been zip tied to the frame rail it had chaffed one of the wires and shorted out. Repaired wire, redid how harness was attached to frame. Problem solved. It think it is a common problem as the mechanic went pretty much straight to the harness when troubleshooting it. It didn't take him long to find it.
    kylefitzy Thanks this.
