Heater core help!!!
Discussion in 'Freightliner Forum' started by Nando85, Aug 17, 2017.
  1. Nando85
    Nando85 Bobtail Member
    43
    6
    Aug 9, 2017
    14liter,Detroit 60 515,egr ugly fixed,south Texas intermodal hauling, so my truck coolant sensor was giving me trouble in hills loaded and empty flush the radiator, using 50/50 pink sca ready stuff, then I cleaned the cac,radiator with air and water, it worked a lot better for about week then my heater core gave out cracked I bypass it then couple days later my sleeper goes out also bypass it currently working normal I guess still around 210 idle hot220 maybe temperature down here is over 100 every day just wondering if anyone knows or symptoms of both heater cores going out????????
  3. Chewey2
    Chewey2 Light Load Member
    67
    53
    Apr 14, 2015
    Rare but not improbalbe. Sounds like someone either ran pure water in it for a while or did not service the cooling system properly and did not do a ph test.
    homeskillet Thanks this.
  4. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Slow down in those rough rail yards and things will stop breaking.
