heater/defrost not working
Discussion in 'Freightliner Forum' started by Driver4Christ, Feb 4, 2013.
  1. Driver4Christ
    Driver4Christ Bobtail Member
    28
    5
    Feb 2, 2013
    Monterey Park, CA
    1999 FLD 120, CAN'T turn on heat could this be electrical? could problem be with on/off knob?
  3. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    could b you didnt turn the hot water on. r/s side of truck down by the frame rail near water pump.
    Driver4Christ Thanks this.
  4. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    older truck,
    could even have by-passed the heater core--if leaking.
  5. Driver4Christ
    28
    5
    Feb 2, 2013
    Monterey Park, CA
    hot water is on, no air thru vent when on high. works a little on 3.. Hope don' t need to dismantle dash to fix problem.
  6. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Sounds like the fan switch is bad, common issue with older freightliners. As it operates on high (some) and doesnt operate on med or low correct?
  7. Jseney12078
    Jseney12078 Light Load Member
    145
    100
    Nov 1, 2012
    Gloversville, NY
    Actually I think the problem could be the resitr board (can't think of the teck name right now) next to the fan. Fan located in front of passenger seat by feet. Should be 7 torq screw to take off cover. When you take off the cover, take your hand and bang on the motor housing, if the motor starts working, then it's your fan motor. Now for the resistor board, normally located to the left of the fan. looks like a circuit board about 2" by 4". When this board goes, you have nothing but high speed on the fan. So your switch won't work on any other speed but high. If you really feel it's your switch, pull the panel off, take the wires of the switch and test them directly. Switches about 35, boards are about 67 and fans run about 150. Any one of these items r really easy to replace. Just remember how you took the wires off, if need be take one off at a time and put onto your new part.
  8. Driver4Christ
    28
    5
    Feb 2, 2013
    Monterey Park, CA
    Thank you for the info, now please tell how I could locate problem of not getting air through vents only through defrost vents. could it be the door not releasing and how do I locate the door.
  9. Jseney12078
    145
    100
    Nov 1, 2012
    Gloversville, NY
    This one is tougher. when you slide the selector to heat, do you hear under the dash the gate open or close? Do yu hear air hissing when you move the selector around? There is more than one door, their located on the blower housing next to the fan. There's an air valve located top left of the housing on the firewall. everything is operated by air. That valve could be toast. Once your aired up, move the selector back and forth, you should hear the doors slaping around. If you don't, Either something fell down inside and is keeping the doors from moving. They r rusted at the hinge, or the actuator valve is toast.. You just have to go from easiest to hardest checking. Good luck.
  10. Dawg7199
    Dawg7199 Bobtail Member
    K
  11. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    better get it fixed quick smart before you start heading out towards those cool places like ID, MT, UT
