Heavy haul
Discussion in 'Experienced Truckers' Advice' started by MrN14, May 13, 2017.
  1. MrN14
    MrN14 Bobtail Member
    17
    48
    Feb 15, 2016
    I own a W900l 2001 with 475 6nz cat with a 10 speed 355 rears . im going to be pulling a 200,000lds load. Think i can mange it if i take it slowly. Dont put to much stress on truck.
  3. bubbavirus
    bubbavirus Medium Load Member
    12 liter, just kidding I don't know jack shift,
  4. okiedokie
    okiedokie Road Train Member
    13,826
    109,445
    Jun 13, 2011
    PNWET
    I hope you don't pull any steep grades.
    RedRover, Lepton1 and ExOTR Thank this.
  5. MrN14
    17
    48
    Feb 15, 2016
    Im hoping to. The load pays $28,000 after expenses should take in $10,000
  6. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    3.55 and a 475?
    I know people trying to haul 84k out of the quarries that have difficulties.
    At 200k, I doubt you could even get moving on a 2% grade.
    I don't know much about heavyhaul, but the guys grossing 130k lbs pulling dozers at the jobsites all seem to have 550+hp running 18 speeds.
    RedRover, Wright77, Lepton1 and 2 others Thank this.
  7. MrN14
    17
    48
    Feb 15, 2016
    Yeah im thinking about pull out of this load. Just dont want to beat the truck down.
  8. AModelCat
    164,495
    Engine HP isn't an issue. That rear axle ratio however, is. 3.55's are road gears. 4.10 - 4.56 would be better suited for heavy work. I would also guess you've probably got 40k rears too? Way too light IMO if that's the case.
  9. MrN14
    17
    48
    Feb 15, 2016
    Yep your right. I think im getting out of it. Until i get a unit that can be spec to haul that weight.
    RedRover and Lepton1 Thank this.
  10. okiedokie
    13,826
    109,445
    Jun 13, 2011
    PNWET
    I have pulled 213,000 on a 13 axle rgn. From Oregon to LA. 550hp/18sp. 6% grades @ 18/21mph. You do the math. If and only if there are no grades more than 4% it could be done. You'll be down in 3rd most likely. Just remember, once you get all that metal rolling it takes alot of real estate to stop it. Plus you will need "good" pilot car drivers. They make all the difference. Good luck.
    Lepton1 Thanks this.
  11. MrN14
    17
    48
    Feb 15, 2016
    Thanks guy for your input. I appreciate it.
