Help anyone?
Discussion in 'Freightliner Forum' started by Jwsplawn, Dec 2, 2016.
  1. Jwsplawn
    Jwsplawn Bobtail Member
    I have a 2010 Cascadia showing an injector code, however it will clear itself off sometimes and run fine. Is there a stupid sensor somewhere that could be causing this issue? Thanks in advance!
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    might be the injector harness but no sensors for that kind of problem .
    Jwsplawn Thanks this.
  4. Jwsplawn
    Ok thank you. I just don't think it is the injector itself so I wanted to start small and go from there.
  5. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    It depends. What does the fault code say? What's the SPN/FMI? It could be your injectors are getting bad.
    DD15/DD13? Mileage?
  6. 1fixitman
    1fixitman Light Load Member
    68
    14
    Aug 16, 2016
    Unscrew the connectors that go into the head for your injector and check to see if there is oil in the connector on the head/valve cover. Simple check and free to do. If it is a connector that unscrews and unplugs.
