Help! FCAN Databus Failure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Driver Glen, Mar 2, 2019.
  1. Driver Glen
    Driver Glen Bobtail Member
    6
    Mar 2, 2019
    I have a 2018 peterbilt 579 with a paccar motor. When I turn the ignition on, all my exterior lights come on including my hazards. The display on the dash reads "FCAN Databus Failure (Exterior Lighting) Pull over Safely and Seek Service"
    My high beams, signals, headlight interrupt and clearance interrupt won't work at all. I have 1000 miles to drive before Monday and no peterbilt dealers are open, what can I do?
    DavidK57918 Thanks this.
  3. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    check all fuses in underhood fuse box. pay close attention to the ones labeled "node"
    DavidK57918, mhyn and Driver Glen Thank this.
  4. Driver Glen
    6
    Mar 2, 2019
    All the fuses seem to be good
  5. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Fuses are labeled G1-G6 on a conventional
    SAR and Driver Glen Thank this.
  6. Driver Glen
    6
    Mar 2, 2019
    I only have a G1 and it's a bus type, I'm not sure how to check those
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Wow that sucks!
    WTH happened to Peterbilt quality anymore?
    I'd be making some calls to the receiver and customer ASAP.
  8. Driver Glen
    6
    Mar 2, 2019
    I know, I'm ready to just go buy a pre emissions truck and get rid of all the bs
    KB3MMX Thanks this.
  9. fxwg1980
    fxwg1980 Bobtail Member
    7
    Mar 2, 2019
    it's probably a bad wire or a data link connection problem. basically it is your chassis node not sending the signal to your cecu or vice versa. I have found bad wires right by the node or behind the front cab mount. you need a wiring diagram, ohm meter and a lot of time.
    DavidK57918 and KB3MMX Thank this.
  10. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    Check the wiring at the support bracket under the LF cab mount just behind the driver steer tire. Commonplace for wiring to rub through and cause issues. I have also found some rubbing on the back of the chassis node below your feet under the cab.
    As already suggested, check all the"G" fuses in the underhood fuse box and dont forget to close the door when your through looking.
  11. Ridgeline
    22,718
    122,941
    is the truck still under warranty?
    KB3MMX Thanks this.
