Hi i have a 2008 volvo 730 isx cummins
im having this active fault code replaced the temp sensor
didnt go away i really dont know what it could be i did have
Both wheel seals replaced because they were leaking ,
any help would be appreciated
thank you
HELP. Front rear axle temp fault
Discussion in 'Volvo Forum' started by Truck4lyfe, Jun 2, 2013.
more than likely the sensor plug in.not the 2 pins,but where the wires end at the plastic plug.happens 90% more than a bad sensor.good luck.
I would agree with quality truck, and if that is not the problem, i would further up there should be another inline plug close to the axle they go bad quite often as well.
damaged wiring in chassis...
Put a test light on the plug an see if your getting power to the sensor a lot of times it's a broken wire not the sensor the wire Will look fine but heat from the rearends n road will break the wire connection every time
