Help getting axle weights correct on end dump with fixed tandems
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by yzman720, Mar 2, 2019.
  1. yzman720
    yzman720 Light Load Member
    57
    11
    Sep 19, 2018
    I heard some where that you can be a small amount over on axle weights when dealing with ag stuff in an end dump? I find it hard to believe but wanted to know if anyone knows? We are an interstate carrier for hire and have 39' end dump. Finding it hard to get axle weights correct since the tandems don't slide on end dump. I know you just have to load correctly but its hard considering when your loaded the only way to adjust a load is to pretty well just shovel a ton of product which obviously want to avoid. I realize you can slide the 5th wheel too, but not being able to slide the tandems on trailer is making it difficult any input is greatly appreciated!
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Find a spot on your company property, dump a dallop. Reweigh. When legal go deliver.
    Eventually that Dallop pile will grow to it's own load. When someone calls for that material shovel it in and go deliver.
    QuietStorm and truckdriver31 Thank this.
  4. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    Many states will allow a little overage as long as gross is good. When you say a little are we talking 500 pounds or 2,000
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    If you're light in the nose, roll forward and mash the brakes. If you're light on the tail, roll backwards and hit the brakes. The more weight you have to shift, the faster you'll have to roll and the harder you'll have to brake. You've only got 1 or maybe 2 real shots to move weight this way, because once it slides and settles in, that's pretty much it. It's a lot easier to move weight back in the trailer than it is forward...and if you need a little more "help" going back, you could always raise the bed a foot or so before backing and braking.
    If you're heavy on the tail, you could always dump a little out of the tailgate...and if that makes you too light, have them add a little to the nose.
    It'd be a cold day in Hell before I'd move a ton or so by hand using a shovel to balance the load...unless, of course, I was caught out & about with portables. The in-ground official scales, well, you know where they are & how to get around them. Takes less time to bypass the scale than it does to man the shovel to get your weights right.
    motocross25 Thanks this.
  6. yzman720
    57
    11
    Sep 19, 2018
    we have prepass, when they weigh you on the fly on the interstate they cant check axle weight only gross correct?
  7. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    How do you think they get your gross weight?
    (Hint: it involves addition)
    If you're over (or even close, if they so choose) on axles or gross, they can red light you and bring you in.
    Bean Jr. Thanks this.
  8. fss99701
    fss99701 Medium Load Member
    327
    663
    Feb 14, 2019
    none of your business
    I seen a lot of tractors that got converted into end dumps they have this type of problem.
    When I used to drive end dump years ago our secret was to avoid the scales! If we had to cross them the second secret was load a little less yardage.
  9. yzman720
    57
    11
    Sep 19, 2018
    Honestly, I really don't know how the scale on the interstate works exactly. That's why I asked that as well. Ya I'm the new guy on prepass everyone can laugh at me but you don't know unless you ask.
  10. Banker
    Banker Road Train Member
    4,506
    14,555
    Aug 19, 2012
    Each state is different but many do allow an overage on an axle group if you aren’t over gross. Some states it is a percentage and others it is a fixed number. Since it isn’t a nationwide variance I guess you will have to google each state you travel in. I found it listed on my states website if you google what you are looking for. Some scale masters like Ky are very understanding and use common sense. 10 inches of a wet, slightly melted and re-frozen snow had me overweight recently in Ky. The scale master told me I had a legit reason and said have a nice day. Had this been in Ohio I would have been sitting there until it melted and left with a ticket, but they generally aren’t reasonable at the Ohio scales. Tennessee has let me ride at 35,000 on the trailer, but under gross. Also Ky has a higher weight limit per axle on state truck routes. I assume other states do as well.
  11. Humblepie
    5,077
    80,318
    Dec 25, 2018
    Or look in the front of your atlas
