Help identifying part/ vibration issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shadow94, Sep 14, 2020.
  1. Shadow94
    Shadow94 Bobtail Member
    7
    Aug 9, 2019
    4F656C61-239E-4934-ACFF-D2E0F0528E38.jpeg 6DC1DE2C-04C4-4ABD-A423-BF35A08E8DD1.jpeg Apparently I’m leaking oil and it’s coming from this part. I drive a 2012 FL cascadia, last 6 is BS7750, engine dd15. Also when I’m doing around 45mph the truck starts to rumble pretty bad, this started happening after I replaced the drive tires.. I checked the wear and psi, everything seems fine. I got an alignment about a month before that when I replaced the steer tires. Maybe I just need another alignment? Any ideas will be appreciated, thank you.
  3. Goodysnap
    Goodysnap Road Train Member
    3,760
    9,165
    Jul 12, 2017
    Im no DD guy, but the part appears like a crankcase seperator module or CCV filter.
    As for the noise/ vibration. Show us what you got for tires. Certain lug tires will make noise, similar to mud tires on a pickup. Noise will ussually lessen as the tires wear.
    Shadow94, spsauerland and Doealex Thank this.
