Help identifying these parts
Discussion in 'Mack Forum' started by Fredy, Jan 25, 2019.
  1. Truckers Report Jobs
  2. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    The top photo is the condenser for the air conditioning and the other one looks like a quick release valve for the air brakes.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    It's the dryer or receiver. Needs to be changed every time the system is opened up.
    mslashbar and Diesel Dave Thank this.
  4. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    The first one is the “Dryer” for the air conditioning. The second one is the quick air release valve which is supposed to be mounted. Depending who does your level 1 inspection, but that’s a OOS until mounted.
    Bean Jr. Thanks this.
  5. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    Condenser looks like a small radiator or cooler. It’s cools the Freon. Usually mounted somewhere in front of the radiator.
  6. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I'm sorry,you're right,it's an accumulater/dryer for the air conditioning system.
    Diesel Dave Thanks this.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Second one is pressure protection valve. It will not allow air out of tank until reaches you 60 or 70 PSI. Common Sealco P/N is 140270.
    Tombstone69 and Humblepie Thank this.
  8. Fredy
    Fredy Light Load Member
    88
    15
    Feb 11, 2016
    Washington, D.C
    Thank you all for the input. I identified the valve as part:
    070-KN31000
    Is it supposed to "leak" air because it has a small pinhole size opening that even the new part has as well.
    Thanks again
  9. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    That pinhole is probably there for a relief when the valve opens and closes.
  10. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Pressure protection valve - used to isolate aux.air from brake air in case of emergency air loss. Is it in between the two air tanks? I can't see where it's going in the picture.
