Help international sleeper window
Discussion in 'Ask An Owner Operator' started by rulonwaholla, Nov 15, 2016.
  1. rulonwaholla
    rulonwaholla Light Load Member
    258
    177
    Nov 6, 2013
    I notice water comes inside my internation left side window when it rains it never did this till now when the window is open it doesnt leak but when i close it starts water coming inside when its raining ?? Im kinda confuse
  3. Ridgeline
    22,696
    122,032
    You need to take the ring off, and check the seal, it may be loose and have to have to be changed because it sounds like when the window is shut, it twists the frame and that leaves gaps between the metal and the window frame that the seal may not be sealing.
    rulonwaholla Thanks this.
  4. rulonwaholla
    258
    177
    Nov 6, 2013
    Im going too check that and thanks i find weird never happen before its soo difficult yoo try too remove interior parts too get too that seal i guess i have too take it too the shop
  5. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    Mine did the same, then started leaking all the time. Seems to be a common problem. I checked and was told the gasket is not a separate item and whole window has to be replaced. Luckily I have a black truck and a strip of gorilla tape keeps it from leaking for about 6 months before it needs to be replaced
  6. Ridgeline
    22,696
    122,032
    Actually guys, there are a few liquid weather stripping things that can be used, I remember I used a silcone based one on my first truck with a seriously leaky sleeper window and it never leaked after that, it was white but paintable. I think 3M made it or maybe GE, crap I'm sorry getting old and can't remember :)
  7. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    The bad news about those windows is most of the interior including the bunks need to be removed to access the nuts that hold the windows in. The leak is due to expansion foam being used instead of a flexible sealant when the trucks were built. I'm seriously considering making mine permanently closed and using a marine grade caulk to fill the gap between the glass and the body sheet metal.
  8. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Go to a parts store or auto body supply and get some windshield adhesive. It is black, and does not attract or hold dust. I've used it on some upper windows in one of my KW's, never leaked again and if done properly is not noticeable.
