Help... Newbie Mixer Driver
Discussion in 'Questions From New Drivers' started by donhow87, Jan 13, 2008.
  1. donhow87
    donhow87 Bobtail Member
    Wichita, KS
    Anyone have advice/wisdom for a new driver who's starting out in a concrete mixer?
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    If it is a front load. Do not stop fast or you will burp out concrete on the road, esp if you have more than 10 yards on. Turn the drum slow going down the road.
  4. palerdr
    palerdr Medium Load Member
    554
    16
    Nov 18, 2007
    albuquerque,n.m
    comes to mind is be safe and don't cement yourself to the highway unless you're pointing in the right direction. There's lots of info here. Just ask if you have a specific question.
  5. hondadrv24
    hondadrv24 Light Load Member
    81
    Aug 20, 2007
    Omaha, Nebraska
    Keep the truck clean, Its no fun chipping concrete out of the drum with a hammer and chisel. Slow down extra around corners, that high center of gravity could cause you to turn over. NEVER park too close to a shoulder, or you may find your truck overturned when you return to it (not from experience here, but what I was told when I started driving Concrete) Good luck,
  6. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Awww. it's not that bad. Gives you something to do to stay on the clock when the weather won't let you work. Ear plugs, dust mask, beat on the fins it falls right off. When you run all the chunks out of the drum it sounds like someone put a cement block in the dryer tho!:biggrin_2559:
  7. poppy
    poppy "I Love that Cushaw Pie"
    263
    114
    Jul 31, 2007
    ky
    take your time, don't let anyone put you in a dangerous position. there is not enough profit in one load of concrete to pay for a truck and hire a new driver. in the spring thaw stay of the shoulder of the road, it will be soft and suck you into the ditch. go easy in wet road, them float tires will slide easy, and most mixers have slick steers, they hate to put tires on a mixer. if you ever get in the shape that you know a load is going to set up on the truck, a bag of sugar will prevent it from setting, forever, so be sure.
  8. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,583
    Jan 1, 2007
    Southeastern Pennsylvania
    A bag of sugar, eh? I did not know that! :yes2557:
  9. poppy
    263
    114
    Jul 31, 2007
    ky
    yeah, it will ruin it, but it won't set. have used it when truck was immobilized and couldn't just run it out on the ground.
    oh, try to not take things personal when contractor give ya a tuff time. most times it is not you at all. it can be the best job and somedays the worst.
    i perfer to haul the ash and cement.
  10. kaydriver1
    kaydriver1 Light Load Member
    222
    Oct 6, 2007
    monett,missouri
    All of these are good points. And like they said a concrete truck is top heavy, always remember that. I have the big floats on my concrete truck, when you turn too sharp in wet grass or mud you keep goin straight. If you will slow down and not turn as sharp it should turn, sometimes on the job if it's real muddy I'll put it in deep reduction to turn, it helps.
  11. poppy
    263
    114
    Jul 31, 2007
    ky
    here in e. ky. we have hills, big, steep. a mixer will climb about anything with a little weight on it. coming down is the trick. real steep, back down. forward they will go a whole lot faster sliding than rolling, they will go like a sled, and scare hell out of ya. so back off a steep hill.lol
