help no cruise control
Discussion in 'Freightliner Forum' started by concon, May 7, 2015.
  1. concon
    concon Bobtail Member
    7
    OK let me try to explain two pressure switches behind break valve in dash. One is for brake lights and the other for cruise control. What if those wires get connected backwards what happens. I think k that is what happened at the t/a when the guy was fixing air leak. Now the pressure switch for brakes is leaking. Could he have hooked all the wires wrong thanks in advanceo
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    If either of them is leaking, it means he cracked it. Replace the leaking one and I bet your cruise starts working.
    Next question, for God's sake, why would you let an idiot ta technician do this? Those guys can't grease a truck properly, let alone work on one.
    flood Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    you can't cross wires. they are all built into plugs that are usually different shapes and sizes. only one place for them plugs to go.
    damage wires maybe.
    as for idiots. not all are that way. and since they work on that sort of crap all day long. they more then likely know what they are doing. specially since some of them have licenses in classes they took. hanging on the walls. sometimes.
  5. Frghter Century 12.7 Detr
    Frghter Century 12.7 Detr Light Load Member
    83
    27
    Mar 6, 2015
    Make sure the valves are the correct ones! They look alike. If you buy the wrong one, the air leak is fixed but something won't work like your cruise control. Look at the number at the bottom of the valve from the old one and compare with new one. What I do is that I found a socket that fits right on it and I used a long socket extension and it comes out right away. Some guys use the wrong tools and damage the porcelain on the valve. Watch your water on the air tanks as moisture gets through all those valves and rust the valves, that's when you get the leaks.
  6. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Yes cause that afternoon tire class a tech took teaches him so much about working behind the dash of a freightliner.
    As for working on"that sort of crap all day long". They work 8 hours a day or so yes. But not on the same make of trucks let alone the same things. One truck it's changing a tail light, the next it's doing an oil change, a few tires, maybe a brake job. Chances are half the techs at your typical truck stop garage have been under the dash of your model truck maybe one in the last year. And considering the pay at truck stops is substantially Less than what they could get at a regular shop or dealer, which again is substantially less than they would get in the garage of a construction company, what quality of mechanics are truck stops getting? Just like the mega carriers with the lowest driver pay get the lowest quality drivers, the lowest pay shops get the lowest quality mechanics. Hell, they can't even say they are mechanics, they are technicians.
  7. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    I trust the t/a mechanics over the mechanics in my companies shop.
  8. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    That's not saying much tho is it.
  9. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    I find T/A / Petro mechanics to be a real crap shoot. A few good ones mixed in with really poor mechanics. I avoid them except for Co trailers.
  10. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    could be a bad wire going to the ECM
    brake lights will work just fine but the ECM thinks you have your foot on the brake so the ECM will not let the CC work
    had it happen..... it was a rusted pin on the plug going to the ECM
  11. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    Thats my point lol. And who cares if cruise doesnt work. Dont and have never used it.
