on my air dryer the terminal for the power, has gone bad can i remove the snap ring and then the heat element or what ever it is, never had to remove that, just want to know if its spring loaded or something else i should b prepared for!!!!
help with air dryer
Discussion in 'Ask An Owner Operator' started by bserious, Aug 20, 2012.
You might get a better responce if you post this in the garage section. Or pm a mod to move it fer ya.
bserious Thanks this. -
The element isn't spring loaded or under air pressure, it sits in a blind hole cavity to warm the purge valve during cold weather operation.
i can simply remove it, or does it screw out
